Not able to ping from ACS engine 4.2
Hi friends,
Got a little problem.
I am able to ping the ACS ENGINE 4.2 from any PC or device. But I am not able to ping any device from the box while logged in via SSH. while I can do so while logged in via console. Is this some kind of bug or is there any patch which after installing will allow me to ping devices from ACS SSH sessions.
Best regards // Rajiv
Nicolas Darchis
Is it the ACS appliance ? If yes, you're not even supposed to be able to ping it unless you apply the pingpatch.
Nicolas
Hi Nicolas,
I applied the patch and I am also able "TO" ping the ACS. The problem is I am not able to ping "FROM" ACS SSH CLI.
BR // Rajiv
Rajiv,
Moving this thread to AAA community.
thanks,
Vinay
Thanks & Regards
