Per User ACL with Wireless LAN Controllers and Cisco Secure ACS5.x Configuration Example??
haibo li
who has Per User ACL with Wireless LAN Controllers and Cisco Secure ACS5.x Configuration Example?
and Per User ACL with Wireless LAN Controllers and Cisco Secure ACS5.x and Active Directory Configuration Example ?
who can help me ?
jan.nielsen
Level 7
Level 7
Are you talking about the ability to send the name of an ACL already configured in the WLC ? If yes, then all you need to do, is send the value "Airespace-ACL-Name" = "name of ACL in WLC", should be in the ACS dictionary already. WLC's however do not support downloadable ACLs like switches do, where the ACL is created in the radius server (ACS, ISE and so on)
it's not name of ACL,it's per user of ACL.   have You  relevant documents??
Not sure what feature you are referring to, in a regular wlc config centrally switched to the WLC from the AP, there is no such feature, are you talking about the FlexConnect mode per user ACL ?
