PPTP problem after user connect in ISR4351/K9
ahmad.rz
hello.
before discuss about my problem sorry for my bad English.
Recently I setup a VPDN in ISR4351 and config radius,aaa, virtual -template,ip local pool ... no problem and user can connect to router as BRAS. Because I want to nat my private ip pool to a valid ip address it's necessary to ping my connected interface for nat action.
After user connected to router and create virtual-access session, user cant ping any connected IP in router except loopback interface which unnumbered in virtual-template interface.
trace from client show nothing and just * as time-out. But debug ip icmp show incoming traffic from client.
I just use "license accept end user agreement" command and reload router but nothing happened.
isr4300-universalk9.03.16.04b.S.155-3.S4b-ext.SPA.bin
Cisco IOS XE Software, Version 03.16.04b.S - Extended Support Release
Cisco IOS Software, ISR Software (X86_64_LINUX_IOSD-UNIVERSALK9-M), Version 15.5(3)S4b, RELEASE SOFTWARE (fc1)
Interesting point is I moved my entire config to a C3845 and it worked fine!
Whats the problem ?
Maybe this help :
Be quick and careful!
0 Replies 0
