11-05-2021 07:19 AM
Hello
We deployed ISE 3.0 to wired network and are using windows native 802.1x supplicants to do both user and machine authentication. The problem is when we RDP into the PC that are connected to 802.1x enabled switch ports, connectivity issues, and session failures and disconnection issues could happen.
So we would like to know if there is a work around to fix this RDP issue if we still want to use windows nativee 802.1x supplicants to do both user and machine authentication, NOT using Cisco AnyConnect Secure Mobility Client with Network Access Manager – NAM module.
Solved! Go to Solution.
11-05-2021 08:37 AM
Looks for me high level as per the information it is more of Windows side setting :
11-05-2021 08:37 AM
11-08-2021 01:03 AM
thank s but not resolved my problem
05-11-2022 07:29 PM
May I know how did you fix your RDP to 802.1x problem?
We have the same issue.
Best regards,
Ed
05-12-2022 02:18 AM
hello
you have to solution the first is to change the authentication mode in the wired card from (user and machine authentication ) to (only user ) or the second solution is to do the authentication with @mac address and you disable the 802.1x authentication in the wired card.
