Problem of connections ports
Ahmed Zniti
we configured tthe cisco switchs to support by ISE version 1.1.1 but We have a issue about some PC Users that cant connected if they changed ports access the on switch the mac address table display that the mac address of Deskyop or Laptop is static even if we put clear arp cache and clear session authentication but the issue persist
jw.sl9
Ahmed,
What version of IOS are you running?
Also, do you have the commands:
snmp-server enable traps mac-notification change move
mac address-table notification change
mac address-table notification mac-move
I hope you find this answer useful, if it was satisfactory  for you, please mark the question as Answered.
Please rate post you consider useful.
-James
I hope you find this information useful, if it was satisfactory for you, please mark the question as Answered. Please rate post you consider useful. -James
the IOS version is 122-55.SE3 the first command (snmp-server enable traps mac-notification change move) exist i will add the two others command and i hope that resolve the issue
Thanks James
