06-24-2021 07:45 AM - edited 06-24-2021 07:57 AM
Hello guys,
I'm new to ISE. After I recovered the admin password, I could log in to ISE via neither SSH nor GUI. Applications are running properly. I tried to ping my default gateway, but it failed. I can only log in to my ISE on VM. Everything worked well before resetting. My ISE version is 1.3.
Could someone please assist?
Solved! Go to Solution.
06-27-2021 02:45 PM
Sounds like a network or VM problem. Call TAC to troubleshoot your installation.
06-24-2021 07:58 AM - edited 06-24-2021 07:59 AM
what kind of reset you did, check the configuration is the basic IP address other stuff available.
show running-config
06-24-2021 08:16 AM - edited 06-24-2021 08:21 AM
Hi, I reset the CLI password of the admin. I've checked the configuration. The IP address and GW are available. I deployed the VM on my pc. I'm able to ping the GW from my pc, but I'm unable to ping the IP address of ISE from my pc.
06-24-2021 09:16 AM
is this working before ?
what is your PC IP address, and ISE IP address, post the show run config ?
is this Lab ?
06-24-2021 10:14 AM
Hi, this lab was working before I reset. I've posted the screenshots. The IP address of my network adapter is 192.168.92.1. I forgot that I set the gateway of my ISE the same as the address of my network adapter. So it must be able to ping the gateway from my pc...
06-25-2021 02:30 AM
Looks something messed up here, hope on your PC you using VMWARE workstation to host ISE.
check the bridge mode settings or NAT
https://www.youtube.com/watch?v=BHpRTVP8upg
06-24-2021 08:00 AM
Hi @Sevion ,
if my understanding is correct, you are able to access ISE via VM's Console and are unable to ping ISE's Default GW from the VM's Console.
Please, use the
ise/admin# show running-config
check the ip address and default gateway configuration.
Hope this helps !!!
06-24-2021 08:19 AM - edited 06-24-2021 10:24 AM
Hi, the IP address and GW are available. I'm unable to ping the IP address of ISE from my pc.
06-27-2021 02:45 PM
