Problem with authentication and authorisation on Cisco ISE
I can't connect to a Wi-Fi network. For authentication and authorization used Cisco ISE v2.2. Access points are managed by the WLC 5760. When device is connected to the network, the device issues Authentication problem. Log WLC 5760 are here:
Mar  5 19:33:24.695: %PARSER-5-CFGLOG_LOGGEDCMD: User:vg  logged command:shell processing
Mar  5 19:33:25.223: %IOSXE-7-PLATFORM: 1 process wcm: 7423.4497.7706 Processing assoc-req station: 7423.4497.7706  AP: 84b8.02c0.9050 -00 thread:-110073160
Mar  5 19:33:25.223: %IOSXE-7-PLATFORM: 1 process wcm: 7423.4497.7706 Association received from mobile on AP  84b8.02c0.9050
Mar  5 19:33:25.223: %IOSXE-7-PLATFORM: 1 process wcm: 7423.4497.7706 qos upstream policy is In_Client_LME_Guest and downstream policy is Eg_Client_LME_Guest
Mar  5 19:33:25.223: %IOSXE-7-PLATFORM: 1 process wcm: 7423.4497.7706 apChanged 0 wlanChanged 1 mscb ipAddr 192.168.111.151, apf RadiusOverride 0x0, numIPv6Addr=0
Mar  5 19:33:25.223: %IOSXE-7-PLATFORM: 1 process wcm: 7423.4497.7706 Applying WLAN policy on MSCB.
Mar  5 19:33:25.223: %IOSXE-7-PLATFORM: 1 process wcm: 7423.4497.7706 Disconnect client immediately due to WLANswitch from 3(LME_Guest) to 10(LME_Employee)
Mar  5 19:33:25.223: %IOSXE-7-PLATFORM: 1 process wcm: 7423.4497.7706 Clean up Mscb after WLAN change
Mar  5 19:33:25.223: %IOSXE-7-PLATFORM: 1 process wcm: 7423.4497.7706 Clear aaa attributes
Mar  5 19:33:25.223: %IOSXE-7-PLATFORM: 1 process wcm: 7423.4497.7706 dot1xapiCleanup Session Stop for dot1x/open client.iifid: 5095c0000f336e capwap id: 76f7000000005f old capwap id:76f7000000005f
Mar  5 19:33:25.223: %IOSXE-7-PLATFORM: 1 process wcm: 7423.4497.7706 Clearing the audit session ID and AAA session id in MSCB
Mar  5 19:33:25.223: %IOSXE-7-PLATFORM: 1 process wcm: 7423.4497.7706 Incrementing the Reassociation Count 1 for client (of interface VLAN311_LME_Guest)
Mar  5 19:33:25.223: %IOSXE-7-PLATFORM: 1 process wcm: 7423.4497.7706 MS got the IP, resetting the Reassociation Count 0 for client
Mar  5 19:33:25.223: %IOSXE-7-PLATFORM: 1 process wcm: 7423.4497.7706 Clearing Address 192.168.111.151 on mobile
Mar  5 19:33:25.224: %IOSXE-7-PLATFORM: 1 process wcm:  7423.4497.7706  192.168.111.151 RUN (20) Skipping TMP rule add
Mar  5 19:33:25.224: %IOSXE-7-PLATFORM: 1 process wcm: 7423.4497.7706 Change state to DHCP_REQD (7) last state RUN (20)
Mar  5 19:33:25.224: %IOSXE-7-PLATFORM: 1 process wcm: 7423.4497.7706 WCDB_CHANGE: Client 1 vlan 311 m_vlan 311 Radio iif id 0x4d2ec000000075 bssid iif id 0x66a380000000fe, bssid 84b8.02c0.9050
Mar  5 19:33:25.224: %IOSXE-7-PLATFORM: 1 process wcm: 7423.4497.7706 WCDB_AUTH: Adding opt82 len 0
Mar  5 19:33:25.224: %IOSXE-7-PLATFORM: 1 process wcm: 7423.4497.7706 WCDB_CHANGE: Suppressing SPI (client pending deletion) pemstate 7 state LEARN_IP(2) vlan 311 client_id 0x5095c0000f336e mob=Local(1) ackflag 2 dropd 0, delete 1
Mar  5 19:33:25.224: %IOSXE-7-PLATFORM: 1 process wcm:  7423.4497.7706  0.0.0.0 DHCP_REQD (7) pemAdvanceState2: MOBILITY-INCOMPLETE with state 7.
Mar  5 19:33:25.225: %IOSXE-7-PLATFORM: 1 process wcm:  7423.4497.7706  0.0.0.0 DHCP_REQD (7) State Update from Mobility-Complete to Mobility-Incomplete
Mar  5 19:33:25.225: %IOSXE-7-PLATFORM: 1 process wcm:  7423.4497.7706  0.0.0.0 DHCP_REQD (7) Reached FAILURE: from line 4334
Mar  5 19:33:25.225: %IOSXE-7-PLATFORM: 1 process wcm: 7423.4497.7706 Reason code 1, Preset 1, AAA cause 1
Mar  5 19:33:25.225: %IOSXE-7-PLATFORM: 1 process wcm: 7423.4497.7706 Scheduling deletion of Mobile Station:  (callerId: 9) in 10 seconds
Mar  5 19:33:25.225: %IOSXE-7-PLATFORM: 1 process wcm: 7423.4497.7706 Cannot delete client entry, IP address is 0
Mar  5 19:33:25.225: %IOSXE-7-PLATFORM: 1 process wcm:  7423.4497.7706  0.0.0.0 DHCP_REQD (7) Deleted mobile LWAPP rule on AP [ 84b8.02c0.9050 ]
Mar  5 19:33:25.226: %IOSXE-7-PLATFORM: 1 process wcm: 7423.4497.7706 Incrementing the Reassociation Count 1 for client (of interface VLAN311_LME_Guest)
Mar  5 19:33:25.226: %IOSXE-7-PLATFORM: 1 process wcm: 7423.4497.7706 Clearing Dhcp state for station  ---
Mar  5 19:33:25.226: %IOSXE-7-PLATFORM: 1 process wcm: 7423.4497.7706 Sending SPI spi_epm_terminate_feature successfullifid: 5095c0000f336e capwap id: 76f7000000005f
Mar  5 19:33:25.226: %IOSXE-7-PLATFORM: 1 process wcm: 7423.4497.7706 Deleting wireless client; Reason code 1, Preset 1, AAA cause 1
Mar  5 19:33:25.226: %IOSXE-7-PLATFORM: 1 process wcm: 7423.4497.7706 WCDB_DEL: Successfully sent
Mar  5 19:33:25.227: %IOSXE-7-PLATFORM: 1 process wcm: 7423.4497.7706 Challenge Fail, already scheduled for deletion
Mar  5 19:33:25.227: %IOSXE-7-PLATFORM: 1 process wcm:  7423.4497.7706  0.0.0.0 DHCP_REQD (7) Handling pemDelScb Event skipping delete
Mar  5 19:33:25.240: %IOSXE-7-PLATFORM: 1 process wcm: 7423.4497.7706 WCDB SPI response msg handler client code 1 mob state 1
Mar  5 19:33:25.240: %IOSXE-7-PLATFORM: 1 process wcm: 7423.4497.7706 apfProcessWcdbClientDelete: Delete ACK from WCDB.
Mar  5 19:33:25.240: %IOSXE-7-PLATFORM: 1 process wcm: 7423.4497.7706 WCDB_DELACK: wcdbAckRecvdFlag updated
Mar  5 19:33:25.240: %IOSXE-7-PLATFORM: 1 process wcm: 7423.4497.7706 WCDB_DELACK: Client IIF Id dealloc SUCCESS w/ 0x5095c0000f336e.
Mar  5 19:33:25.240: %IOSXE-7-PLATFORM: 1 process wcm: 7423.4497.7706 Invoked platform delete and cleared handle
Mar  5 19:33:25.240: %IOSXE-7-PLATFORM: 1 process wcm: 7423.4497.7706 Deleting mobile on AP  84b8.02c0.9050 (0)
Mar  5 19:33:25.240: %IOSXE-7-PLATFORM: 1 process wcm: 7423.4497.7706 Calling SM stop unconditionally for dot1x/open   ifid: 0 capwap id: 76f7000000005f old capwap id:76f7000000005f
Mar  5 19:33:25.240: %IOSXE-7-PLATFORM: 1 process wcm: 7423.4497.7706 Unlinked and freed mscb
Mar  5 19:33:25.721: %AUTHMGR-4-UNAUTH_MOVE: (slow) MAC address (3084.5437.e218) from Ca60 to Ca2
Mar  5 19:33:25.753: %IOSXE-7-PLATFORM: 1 process wcm: 7423.4497.7706 Processing assoc-req station: 7423.4497.7706  AP: 84b8.02c0.9050 -00 thread:-110073160
Mar  5 19:33:25.753: %IOSXE-7-PLATFORM: 1 process wcm: 7423.4497.7706 Adding mobile on LWAPP AP  84b8.02c0.9050 (0)
Mar  5 19:33:25.753: %IOSXE-7-PLATFORM: 1 process wcm: 7423.4497.7706  Creating WL station entry for client -  rc 0
Mar  5 19:33:25.753: %IOSXE-7-PLATFORM: 1 process wcm: 7423.4497.7706 Association received from mobile on AP  84b8.02c0.9050
Mar  5 19:33:25.753: %IOSXE-7-PLATFORM: 1 process wcm: 7423.4497.7706 apChanged 0 wlanChanged 0 mscb ipAddr 0.0.0.0, apf RadiusOverride 0x0, numIPv6Addr=0
Mar  5 19:33:25.753: %IOSXE-7-PLATFORM: 1 process wcm: 7423.4497.7706 Applying WLAN policy on MSCB.
Mar  5 19:33:25.753: %IOSXE-7-PLATFORM: 1 process wcm: 7423.4497.7706 Applying WLAN ACL policies to client
Mar  5 19:33:25.753: %IOSXE-7-PLATFORM: 1 process wcm: 7423.4497.7706 No Interface ACL used for Wireless client in WCM(NGWC)
Mar  5 19:33:25.753: %IOSXE-7-PLATFORM: 1 process wcm: 7423.4497.7706 Applying site-specific IPv6 override for station  7423.4497.7706  - vapId 10, site 'default-group', interface 'VLAN311_LME_Guest'
Mar  5 19:33:25.754: %IOSXE-7-PLATFORM: 1 process wcm: 7423.4497.7706 Applying local bridging Interface Policy for station  7423.4497.7706  - vlan 311, interface 'VLAN311_LME_Guest'
Mar  5 19:33:25.754: %IOSXE-7-PLATFORM: 1 process wcm: 7423.4497.7706 STA - rates (8): 2 4 11 22 12 18 24 36 0 0 0 0 0 0 0 0
Mar  5 19:33:25.754: %IOSXE-7-PLATFORM: 1 process wcm: 7423.4497.7706 STA - rates (12): 2 4 11 22 12 18 24 36 48 72 96 108 0 0 0 0
Mar  5 19:33:25.754: %IOSXE-7-PLATFORM: 1 process wcm: 7423.4497.7706 Received 802.11i 802.1X key management suite, enabling dot1x Authentication
Mar  5 19:33:25.754: %IOSXE-7-PLATFORM: 1 process wcm: 7423.4497.7706 new capwap_wtp_iif_id 76f7000000005f, sm capwap_wtp_iif_id 0
Mar  5 19:33:25.754: %IOSXE-7-PLATFORM: 1 process wcm: 7423.4497.7706 WCDB_ADD: Radio IIFID 0x4d2ec000000075, BSSID IIF Id 0x57a500000f31b8, COS 4
Mar  5 19:33:25.754: %IOSXE-7-PLATFORM: 1 process wcm: 7423.4497.7706 WCDB_ADD: Anchor Sw  1, Doppler 1
Mar  5 19:33:25.754: %IOSXE-7-PLATFORM: 1 process wcm: 7423.4497.7706 WCDB_ALLOCATE: Client IIF Id alloc SUCCESS w/ client 738540000f33e1 (state 0).
Mar  5 19:33:25.755: %IOSXE-7-PLATFORM: 1 process wcm: 7423.4497.7706 iifid Clearing Ack flag
Mar  5 19:33:25.755: %IOSXE-7-PLATFORM: 1 process wcm: 7423.4497.7706 WCDB_ADD: Platform ID allocated successfully ID:3819
Mar  5 19:33:25.755: %IOSXE-7-PLATFORM: 1 process wcm: 7423.4497.7706 WCDB_ADD: Adding opt82 len 0
Mar  5 19:33:25.755: %IOSXE-7-PLATFORM: 1 process wcm: 7423.4497.7706 WCDB_ADD: Cleaering Ack flag
Mar  5 19:33:25.755: %IOSXE-7-PLATFORM: 1 process wcm: 7423.4497.7706 WCDB_ADD: ssid LME_Employee bssid 84b8.02c0.9050 vlan 311 auth=ASSOCIATION(0) wlan(ap-group/global) 10/10 client 0 assoc 74 mob=Unassoc(0) radio 0
Mar  5 19:33:25.755: %IOSXE-7-PLATFORM: 1 process wcm: 7423.4497.7706 m_vlan 311 ip 0.0.0.0 src 0x76f7000000005f dst 0x0 cid 0x738540000f33e1 glob rsc id 3819 dhcpsrv  192.168.96.1  type 0 IPSG off
Mar  5 19:33:25.756: %IOSXE-7-PLATFORM: 1 process wcm: 7423.4497.7706 WCDB_ADD: mscb iifid 0x738540000f33e1 msinfo iifid 0x0
Mar  5 19:33:25.756: %IOSXE-7-PLATFORM: 1 process wcm:  7423.4497.7706  0.0.0.0 START (0) Initializing policy
Mar  5 19:33:25.756: %IOSXE-7-PLATFORM: 1 process wcm: 7423.4497.7706 Change state to AUTHCHECK (2) last state START (0)
Mar  5 19:33:25.756: %IOSXE-7-PLATFORM: 1 process wcm: 7423.4497.7706 Change state to 8021X_REQD (3) last state AUTHCHECK (2)
Mar  5 19:33:25.756: %IOSXE-7-PLATFORM: 1 process wcm:  7423.4497.7706  0.0.0.0 8021X_REQD (3) DHCP Not required on AP  84b8.02c0.9050  vapId 10 apVapId 10for this client
Mar  5 19:33:25.756: %IOSXE-7-PLATFORM: 1 process wcm: 7423.4497.7706 Not Using WMM Compliance code qosCap 00
Mar  5 19:33:25.757: %IOSXE-7-PLATFORM: 1 process wcm:  7423.4497.7706  0.0.0.0 8021X_REQD (3) Plumbed mobile LWAPP rule on AP  84b8.02c0.9050  vapId 10 apVapId 10
Mar  5 19:33:25.757: %IOSXE-7-PLATFORM: 1 process wcm: 7423.4497.7706 apfPemAddUser2 (apf_policy.c:204) Changing state for mobile  7423.4497.7706  on AP  84b8.02c0.9050  from Idle to Associated
Mar  5 19:33:25.757: %IOSXE-7-PLATFORM: 1 process wcm: 7423.4497.7706 Stopping deletion of Mobile Station: (callerId: 48)
Mar  5 19:33:25.757: %IOSXE-7-PLATFORM: 1 process wcm: 7423.4497.7706 Ms Timeout = 0, Session Timeout = 300
Mar  5 19:33:25.757: %IOSXE-7-PLATFORM: 1 process wcm: 7423.4497.7706 Sending assoc-resp station: 7423.4497.7706  AP: 84b8.02c0.9050 -00 thread:-110073160
Mar  5 19:33:25.758: %IOSXE-7-PLATFORM: 1 process wcm: 7423.4497.7706 Sending Assoc Response to station on BSSID  84b8.02c0.9050  (status 0) ApVapId 10 Slot 0
Mar  5 19:33:25.758: %IOSXE-7-PLATFORM: 1 process wcm: 7423.4497.7706 apfProcessAssocReq (apf_80211.c:6359) Changing state for mobile  7423.4497.7706  on AP  84b8.02c0.9050  from Associated to Associated
Mar  5 19:33:25.762: %IOSXE-7-PLATFORM: 1 process wcm: 7423.4497.7706 Session start for dot1x/open client. iifid: 738540000f33e1 capwap id: 76f7000000005f old capwap id:0
Mar  5 19:33:25.915: %IOSXE-7-PLATFORM: 1 process wcm: 7423.4497.7706 Not comparing because the ACLs have not been sent yet.
Mar  5 19:33:25.915: %IOSXE-7-PLATFORM: 1 process wcm: 7423.4497.7706 Final flag values are, epmSendAcl 1, epmSendAclDone 0
Mar  5 19:33:25.915: %IOSXE-7-PLATFORM: 1 process wcm: 7423.4497.7706  client incoming attribute size are 670
Mar  5 19:33:25.922: %IOSXE-7-PLATFORM: 1 process wcm: 7423.4497.7706 Session Update for dot1x/open client.iifid: 738540000f33e1 capwap id: 76f7000000005f old capwap id:76f7000000005f
paul46
Hi Ilya
You need to provide more details
What kind of device are you authenticating? Is it 802.1x?
Post your ISE authentication and authorization policy?
Have you integrated wireless controller to ISE?
paul46
Hi Ilya
1. What kind of device are you authenticating? Is it 802.1x?
I'm using Android device. Yes, it's 802.1x
2. Have you integrated wireless controller to ISE?
Yes. I'm integrated wireless controller to ISE. I'm configured the RADIUS SERVER, Server group and Method List. Created and setting WLAN. In the attachment screenshots with settings.
3. Post your ISE authentication and authorization policy?
Policy Authentication created in the following way:
Standart rule 1       :   if Airespace:Airespace-Wlan-id EQUALS 10 Allow protocols: Default Network Access and
Default :Use Internal users
Policy Authorization created in the following way:
Standart rule 1       : if LME_Guest AND (Airespace:Airespace-Wlan-id EQUALS 10) then: PermitAccess
tell me please where to look for the problem? On ISE or WLC?
Replace Airspace condition in your authentication policy to below
Standart rule 1      If Wireless_802.1X
you are using Default :Use Internal users as a store. Is your Android device corporate? does it have certificate? In that case, you need to create a Certificate Authentication Profile and change your Internal Users store to new one
I replaced Airspace condition in authentication policy on the following (this authentication policy default):
Dot1x       :   if Wired_802.1x OR Wireless_802.1X Allow protocols: Default Network Access and
Default: Use All_User_ID_Stores
Policy Authorization:
Standart rule 1       : if LME_Guest AND (Wireless_802.1X AND Airespace:Airespace-Wlan-id EQUALS 10) then: PermitAccess
But my device is still not authenticated, and this applies not only to my device. Other devices also not authenticated.
1. Is your Android device corporate?
No, this is my personal device. Corporate devices also do not connect to Wi-Fi. Logs on ISE indicate that authentication is successful, however I do not connect to the Wi-Fi network, Authentication problem.
2. does it have certificate?
No, can I do without a certificate? I can connect to the network without using a certificate? On Daloradius we connected without using certificates.
