Problem with authentication and authorization dot1x on Cisco ISE
Good day.
I have a problem. I can't connect to Wi-Fi network through the Android device and other device. For authentication and authorization used Cisco ISE v2.2. Wireless controller WLC 5760 are manages the access points.
On WLC I configured the RADIUS SERVER, Server group and Method List. Also I created and configured WLAN. In the attachment screenshots with settings.
Policy Authentication created in the following way:
Standart rule 1       :   if Airespace:Airespace-Wlan-id EQUALS 10 Allow protocols: Default Network Access and
Default :Use Internal users
Policy Authorization created in the following way:
Standart rule 1       : if LME_Guest AND (Airespace:Airespace-Wlan-id EQUALS 10) then: PermitAccess
When device is connected to the network, the device issues Authentication problem. Log WLC 5760 are here:
Mar  5 19:33:24.695: %PARSER-5-CFGLOG_LOGGEDCMD: User:vg  logged command:shell processing
Mar  5 19:33:25.223: %IOSXE-7-PLATFORM: 1 process wcm: 7423.4497.7706 Processing assoc-req station: 7423.4497.7706  AP: 84b8.02c0.9050 -00 thread:-110073160
Mar  5 19:33:25.223: %IOSXE-7-PLATFORM: 1 process wcm: 7423.4497.7706 Association received from mobile on AP  84b8.02c0.9050
Mar  5 19:33:25.223: %IOSXE-7-PLATFORM: 1 process wcm: 7423.4497.7706 qos upstream policy is In_Client_LME_Guest and downstream policy is Eg_Client_LME_Guest
Mar  5 19:33:25.223: %IOSXE-7-PLATFORM: 1 process wcm: 7423.4497.7706 apChanged 0 wlanChanged 1 mscb ipAddr 192.168.111.151, apf RadiusOverride 0x0, numIPv6Addr=0
Mar  5 19:33:25.223: %IOSXE-7-PLATFORM: 1 process wcm: 7423.4497.7706 Applying WLAN policy on MSCB.
Mar  5 19:33:25.223: %IOSXE-7-PLATFORM: 1 process wcm: 7423.4497.7706 Disconnect client immediately due to WLANswitch from 3(LME_Guest) to 10(LME_Employee)
Mar  5 19:33:25.223: %IOSXE-7-PLATFORM: 1 process wcm: 7423.4497.7706 Clean up Mscb after WLAN change
Mar  5 19:33:25.223: %IOSXE-7-PLATFORM: 1 process wcm: 7423.4497.7706 Clear aaa attributes
Mar  5 19:33:25.223: %IOSXE-7-PLATFORM: 1 process wcm: 7423.4497.7706 dot1xapiCleanup Session Stop for dot1x/open client.iifid: 5095c0000f336e capwap id: 76f7000000005f old capwap id:76f7000000005f
Mar  5 19:33:25.223: %IOSXE-7-PLATFORM: 1 process wcm: 7423.4497.7706 Clearing the audit session ID and AAA session id in MSCB
Mar  5 19:33:25.223: %IOSXE-7-PLATFORM: 1 process wcm: 7423.4497.7706 Incrementing the Reassociation Count 1 for client (of interface VLAN311_LME_Guest)
Mar  5 19:33:25.223: %IOSXE-7-PLATFORM: 1 process wcm: 7423.4497.7706 MS got the IP, resetting the Reassociation Count 0 for client
Mar  5 19:33:25.223: %IOSXE-7-PLATFORM: 1 process wcm: 7423.4497.7706 Clearing Address 192.168.111.151 on mobile
Mar  5 19:33:25.224: %IOSXE-7-PLATFORM: 1 process wcm:  7423.4497.7706  192.168.111.151 RUN (20) Skipping TMP rule add
Mar  5 19:33:25.224: %IOSXE-7-PLATFORM: 1 process wcm: 7423.4497.7706 Change state to DHCP_REQD (7) last state RUN (20)
Mar  5 19:33:25.224: %IOSXE-7-PLATFORM: 1 process wcm: 7423.4497.7706 WCDB_CHANGE: Client 1 vlan 311 m_vlan 311 Radio iif id 0x4d2ec000000075 bssid iif id 0x66a380000000fe, bssid 84b8.02c0.9050
Mar  5 19:33:25.224: %IOSXE-7-PLATFORM: 1 process wcm: 7423.4497.7706 WCDB_AUTH: Adding opt82 len 0
Mar  5 19:33:25.224: %IOSXE-7-PLATFORM: 1 process wcm: 7423.4497.7706 WCDB_CHANGE: Suppressing SPI (client pending deletion) pemstate 7 state LEARN_IP(2) vlan 311 client_id 0x5095c0000f336e mob=Local(1) ackflag 2 dropd 0, delete 1
Mar  5 19:33:25.224: %IOSXE-7-PLATFORM: 1 process wcm:  7423.4497.7706  0.0.0.0 DHCP_REQD (7) pemAdvanceState2: MOBILITY-INCOMPLETE with state 7.
Mar  5 19:33:25.225: %IOSXE-7-PLATFORM: 1 process wcm:  7423.4497.7706  0.0.0.0 DHCP_REQD (7) State Update from Mobility-Complete to Mobility-Incomplete
Mar  5 19:33:25.225: %IOSXE-7-PLATFORM: 1 process wcm:  7423.4497.7706  0.0.0.0 DHCP_REQD (7) Reached FAILURE: from line 4334
Mar  5 19:33:25.225: %IOSXE-7-PLATFORM: 1 process wcm: 7423.4497.7706 Reason code 1, Preset 1, AAA cause 1
Mar  5 19:33:25.225: %IOSXE-7-PLATFORM: 1 process wcm: 7423.4497.7706 Scheduling deletion of Mobile Station:  (callerId: 9) in 10 seconds
Mar  5 19:33:25.225: %IOSXE-7-PLATFORM: 1 process wcm: 7423.4497.7706 Cannot delete client entry, IP address is 0
Mar  5 19:33:25.225: %IOSXE-7-PLATFORM: 1 process wcm:  7423.4497.7706  0.0.0.0 DHCP_REQD (7) Deleted mobile LWAPP rule on AP [ 84b8.02c0.9050 ]
Mar  5 19:33:25.226: %IOSXE-7-PLATFORM: 1 process wcm: 7423.4497.7706 Incrementing the Reassociation Count 1 for client (of interface VLAN311_LME_Guest)
Mar  5 19:33:25.226: %IOSXE-7-PLATFORM: 1 process wcm: 7423.4497.7706 Clearing Dhcp state for station  ---
Mar  5 19:33:25.226: %IOSXE-7-PLATFORM: 1 process wcm: 7423.4497.7706 Sending SPI spi_epm_terminate_feature successfullifid: 5095c0000f336e capwap id: 76f7000000005f
Mar  5 19:33:25.226: %IOSXE-7-PLATFORM: 1 process wcm: 7423.4497.7706 Deleting wireless client; Reason code 1, Preset 1, AAA cause 1
Mar  5 19:33:25.226: %IOSXE-7-PLATFORM: 1 process wcm: 7423.4497.7706 WCDB_DEL: Successfully sent
Mar  5 19:33:25.227: %IOSXE-7-PLATFORM: 1 process wcm: 7423.4497.7706 Challenge Fail, already scheduled for deletion
Mar  5 19:33:25.227: %IOSXE-7-PLATFORM: 1 process wcm:  7423.4497.7706  0.0.0.0 DHCP_REQD (7) Handling pemDelScb Event skipping delete
Mar  5 19:33:25.240: %IOSXE-7-PLATFORM: 1 process wcm: 7423.4497.7706 WCDB SPI response msg handler client code 1 mob state 1
Mar  5 19:33:25.240: %IOSXE-7-PLATFORM: 1 process wcm: 7423.4497.7706 apfProcessWcdbClientDelete: Delete ACK from WCDB.
Mar  5 19:33:25.240: %IOSXE-7-PLATFORM: 1 process wcm: 7423.4497.7706 WCDB_DELACK: wcdbAckRecvdFlag updated
Mar  5 19:33:25.240: %IOSXE-7-PLATFORM: 1 process wcm: 7423.4497.7706 WCDB_DELACK: Client IIF Id dealloc SUCCESS w/ 0x5095c0000f336e.
Mar  5 19:33:25.240: %IOSXE-7-PLATFORM: 1 process wcm: 7423.4497.7706 Invoked platform delete and cleared handle
Mar  5 19:33:25.240: %IOSXE-7-PLATFORM: 1 process wcm: 7423.4497.7706 Deleting mobile on AP  84b8.02c0.9050 (0)
Mar  5 19:33:25.240: %IOSXE-7-PLATFORM: 1 process wcm: 7423.4497.7706 Calling SM stop unconditionally for dot1x/open   ifid: 0 capwap id: 76f7000000005f old capwap id:76f7000000005f
Mar  5 19:33:25.240: %IOSXE-7-PLATFORM: 1 process wcm: 7423.4497.7706 Unlinked and freed mscb
Mar  5 19:33:25.721: %AUTHMGR-4-UNAUTH_MOVE: (slow) MAC address (3084.5437.e218) from Ca60 to Ca2
Mar  5 19:33:25.753: %IOSXE-7-PLATFORM: 1 process wcm: 7423.4497.7706 Processing assoc-req station: 7423.4497.7706  AP: 84b8.02c0.9050 -00 thread:-110073160
Mar  5 19:33:25.753: %IOSXE-7-PLATFORM: 1 process wcm: 7423.4497.7706 Adding mobile on LWAPP AP  84b8.02c0.9050 (0)
Mar  5 19:33:25.753: %IOSXE-7-PLATFORM: 1 process wcm: 7423.4497.7706  Creating WL station entry for client -  rc 0
Mar  5 19:33:25.753: %IOSXE-7-PLATFORM: 1 process wcm: 7423.4497.7706 Association received from mobile on AP  84b8.02c0.9050
Mar  5 19:33:25.753: %IOSXE-7-PLATFORM: 1 process wcm: 7423.4497.7706 apChanged 0 wlanChanged 0 mscb ipAddr 0.0.0.0, apf RadiusOverride 0x0, numIPv6Addr=0
Mar  5 19:33:25.753: %IOSXE-7-PLATFORM: 1 process wcm: 7423.4497.7706 Applying WLAN policy on MSCB.
Mar  5 19:33:25.753: %IOSXE-7-PLATFORM: 1 process wcm: 7423.4497.7706 Applying WLAN ACL policies to client
Mar  5 19:33:25.753: %IOSXE-7-PLATFORM: 1 process wcm: 7423.4497.7706 No Interface ACL used for Wireless client in WCM(NGWC)
Mar  5 19:33:25.753: %IOSXE-7-PLATFORM: 1 process wcm: 7423.4497.7706 Applying site-specific IPv6 override for station  7423.4497.7706  - vapId 10, site 'default-group', interface 'VLAN311_LME_Guest'
Mar  5 19:33:25.754: %IOSXE-7-PLATFORM: 1 process wcm: 7423.4497.7706 Applying local bridging Interface Policy for station  7423.4497.7706  - vlan 311, interface 'VLAN311_LME_Guest'
Mar  5 19:33:25.754: %IOSXE-7-PLATFORM: 1 process wcm: 7423.4497.7706 STA - rates (8): 2 4 11 22 12 18 24 36 0 0 0 0 0 0 0 0
Mar  5 19:33:25.754: %IOSXE-7-PLATFORM: 1 process wcm: 7423.4497.7706 STA - rates (12): 2 4 11 22 12 18 24 36 48 72 96 108 0 0 0 0
Mar  5 19:33:25.754: %IOSXE-7-PLATFORM: 1 process wcm: 7423.4497.7706 Received 802.11i 802.1X key management suite, enabling dot1x Authentication
Mar  5 19:33:25.754: %IOSXE-7-PLATFORM: 1 process wcm: 7423.4497.7706 new capwap_wtp_iif_id 76f7000000005f, sm capwap_wtp_iif_id 0
Mar  5 19:33:25.754: %IOSXE-7-PLATFORM: 1 process wcm: 7423.4497.7706 WCDB_ADD: Radio IIFID 0x4d2ec000000075, BSSID IIF Id 0x57a500000f31b8, COS 4
Mar  5 19:33:25.754: %IOSXE-7-PLATFORM: 1 process wcm: 7423.4497.7706 WCDB_ADD: Anchor Sw  1, Doppler 1
Mar  5 19:33:25.754: %IOSXE-7-PLATFORM: 1 process wcm: 7423.4497.7706 WCDB_ALLOCATE: Client IIF Id alloc SUCCESS w/ client 738540000f33e1 (state 0).
Mar  5 19:33:25.755: %IOSXE-7-PLATFORM: 1 process wcm: 7423.4497.7706 iifid Clearing Ack flag
Mar  5 19:33:25.755: %IOSXE-7-PLATFORM: 1 process wcm: 7423.4497.7706 WCDB_ADD: Platform ID allocated successfully ID:3819
Mar  5 19:33:25.755: %IOSXE-7-PLATFORM: 1 process wcm: 7423.4497.7706 WCDB_ADD: Adding opt82 len 0
Mar  5 19:33:25.755: %IOSXE-7-PLATFORM: 1 process wcm: 7423.4497.7706 WCDB_ADD: Cleaering Ack flag
Mar  5 19:33:25.755: %IOSXE-7-PLATFORM: 1 process wcm: 7423.4497.7706 WCDB_ADD: ssid LME_Employee bssid 84b8.02c0.9050 vlan 311 auth=ASSOCIATION(0) wlan(ap-group/global) 10/10 client 0 assoc 74 mob=Unassoc(0) radio 0
Mar  5 19:33:25.755: %IOSXE-7-PLATFORM: 1 process wcm: 7423.4497.7706 m_vlan 311 ip 0.0.0.0 src 0x76f7000000005f dst 0x0 cid 0x738540000f33e1 glob rsc id 3819 dhcpsrv  192.168.96.1  type 0 IPSG off
Mar  5 19:33:25.756: %IOSXE-7-PLATFORM: 1 process wcm: 7423.4497.7706 WCDB_ADD: mscb iifid 0x738540000f33e1 msinfo iifid 0x0
Mar  5 19:33:25.756: %IOSXE-7-PLATFORM: 1 process wcm:  7423.4497.7706  0.0.0.0 START (0) Initializing policy
Mar  5 19:33:25.756: %IOSXE-7-PLATFORM: 1 process wcm: 7423.4497.7706 Change state to AUTHCHECK (2) last state START (0)
Mar  5 19:33:25.756: %IOSXE-7-PLATFORM: 1 process wcm: 7423.4497.7706 Change state to 8021X_REQD (3) last state AUTHCHECK (2)
Mar  5 19:33:25.756: %IOSXE-7-PLATFORM: 1 process wcm:  7423.4497.7706  0.0.0.0 8021X_REQD (3) DHCP Not required on AP  84b8.02c0.9050  vapId 10 apVapId 10for this client
Mar  5 19:33:25.756: %IOSXE-7-PLATFORM: 1 process wcm: 7423.4497.7706 Not Using WMM Compliance code qosCap 00
Mar  5 19:33:25.757: %IOSXE-7-PLATFORM: 1 process wcm:  7423.4497.7706  0.0.0.0 8021X_REQD (3) Plumbed mobile LWAPP rule on AP  84b8.02c0.9050  vapId 10 apVapId 10
Mar  5 19:33:25.757: %IOSXE-7-PLATFORM: 1 process wcm: 7423.4497.7706 apfPemAddUser2 (apf_policy.c:204) Changing state for mobile  7423.4497.7706  on AP  84b8.02c0.9050  from Idle to Associated
Mar  5 19:33:25.757: %IOSXE-7-PLATFORM: 1 process wcm: 7423.4497.7706 Stopping deletion of Mobile Station: (callerId: 48)
Mar  5 19:33:25.757: %IOSXE-7-PLATFORM: 1 process wcm: 7423.4497.7706 Ms Timeout = 0, Session Timeout = 300
Mar  5 19:33:25.757: %IOSXE-7-PLATFORM: 1 process wcm: 7423.4497.7706 Sending assoc-resp station: 7423.4497.7706  AP: 84b8.02c0.9050 -00 thread:-110073160
Mar  5 19:33:25.758: %IOSXE-7-PLATFORM: 1 process wcm: 7423.4497.7706 Sending Assoc Response to station on BSSID  84b8.02c0.9050  (status 0) ApVapId 10 Slot 0
Mar  5 19:33:25.758: %IOSXE-7-PLATFORM: 1 process wcm: 7423.4497.7706 apfProcessAssocReq (apf_80211.c:6359) Changing state for mobile  7423.4497.7706  on AP  84b8.02c0.9050  from Associated to Associated
Mar  5 19:33:25.762: %IOSXE-7-PLATFORM: 1 process wcm: 7423.4497.7706 Session start for dot1x/open client. iifid: 738540000f33e1 capwap id: 76f7000000005f old capwap id:0
Mar  5 19:33:25.915: %IOSXE-7-PLATFORM: 1 process wcm: 7423.4497.7706 Not comparing because the ACLs have not been sent yet.
Mar  5 19:33:25.915: %IOSXE-7-PLATFORM: 1 process wcm: 7423.4497.7706 Final flag values are, epmSendAcl 1, epmSendAclDone 0
Mar  5 19:33:25.915: %IOSXE-7-PLATFORM: 1 process wcm: 7423.4497.7706  client incoming attribute size are 670
Mar  5 19:33:25.922: %IOSXE-7-PLATFORM: 1 process wcm: 7423.4497.7706 Session Update for dot1x/open client.iifid: 738540000f33e1 capwap id: 76f7000000005f old capwap id:76f7000000005f
Could you tell me please where to look for the problem? On ISE or WLC?
22 Replies 22
Francesco Molino
On your screenshots the ports for ISE on wlc aren't correct. Ports are 1812 for authentication and 1813 for accounting.
Then LME_GUEST on your ISE policy corresponds to local ISE group, right?
Do you see any authentication requests on ISE? If yes, can you share the log from ISE?
Francesco
PS: Please don't forget to rate and select as validated answer if this answered your question
1. On your screenshots the ports for ISE on wlc aren't correct. Ports are 1812 for authentication and 1813 for accounting.
Thank you for your comment.
I fixed the ports on WLC, but it did't help, my device is not authenticated.
2. Then LME_GUEST on your ISE policy corresponds to local ISE group, right?
Yes, right! I created and added Users in group LME_Guest on ISE.
3. Do you see any authentication requests on ISE? If yes, can you share the log from ISE?
Yes, I see authentication requests on ISE. Logs indicate that authentication is successful, however I do not connect to the Wi-Fi network, Authentication problem. I
Steps authentication is here:
Шаги аутентификации
11001
Received RADIUS Access-Request
11017
RADIUS created a new session
15049
Evaluating Policy Group
15008
Evaluating Service Selection Policy
15048
Queried PIP - NormalisedRadius.RadiusFlowType
15048
Queried PIP - Airespace.Airespace-Wlan-Id
15004
Matched rule - LME_Guest Authentication
11507
Extracted EAP-Response/Identity
12500
Prepared EAP-Request proposing EAP-TLS with challenge
12625
Valid EAP-Key-Name attribute received
11006
Returned RADIUS Access-Challenge
11001
11018
RADIUS is re-using an existing session
12301
Extracted EAP-Response/NAK requesting to use PEAP instead
12300
Prepared EAP-Request proposing PEAP with challenge
12625
11006
11001
11018
12302
Extracted EAP-Response containing PEAP challenge-response and accepting PEAP as negotiated
12319
Successfully negotiated PEAP version 1
12800
Extracted first TLS record; TLS handshake started
12805
Extracted TLS ClientHello message
12806
Prepared TLS ServerHello message
12807
Prepared TLS Certificate message
12810
Prepared TLS ServerDone message
12305
Prepared EAP-Request with another PEAP challenge
11006
11001
11018
12304
12305
11006
11001
11018
12304
12319
12812
Extracted TLS ClientKeyExchange message
12813
Extracted TLS CertificateVerify message
12804
Extracted TLS Finished message
12801
Prepared TLS ChangeCipherSpec message
12802
Prepared TLS Finished message
12816
TLS handshake succeeded
12310
PEAP full handshake finished successfully
12832
Tunnel build with local server certificate is not yet active or it has already expired
12305
11006
11001
11018
12304
12313
PEAP inner method started
11521
Prepared EAP-Request/Identity for inner EAP method
12305
11006
11001
11018
12304
11522
Extracted EAP-Response/Identity for inner EAP method
11806
Prepared EAP-Request for inner method proposing EAP-MSCHAP with challenge
12305
11006
11001
11018
12304
11808
Extracted EAP-Response containing EAP-MSCHAP challenge-response for inner method and accepting EAP-MSCHAP as negotiated
15041
Evaluating Identity Policy
15006
Matched Default Rule
15013
Selected Identity Source - Internal Users
24210
Looking up User in Internal Users IDStore - amedzhbel
24212
Found User in Internal Users IDStore
22037
Authentication Passed
11824
EAP-MSCHAP authentication attempt passed
12305
11006
11001
11018
12304
11810
Extracted EAP-Response for inner method containing MSCHAP challenge-response
11814
Inner EAP-MSCHAP authentication succeeded
11519
Prepared EAP-Success for inner EAP method
12314
PEAP inner method finished successfully
12305
11006
11001
11018
12304
24423
ISE has not been able to confirm previous successful machine authentication
15036
Evaluating Authorization Policy
15048
Queried PIP - Radius.NAS-Port-Type
15004
Matched rule - LME_GUEST_Access
15016
Selected Authorization Profile - PermitAccess
12306
PEAP authentication succeeded
11503
11002
Returned RADIUS Access-Accept
On ISE, everything looks like good.
On your WLC, you're getting this error:
Can you share output of show wlan x ?
Francesco
In the attachment output data show wlan x.
I understand correctly, the problem is still not in ISE?
When you are using 802.1x, authentication happens first and once it is successful then the WLC on behalf of the client (IF YOU ARE USING DHCP PROXY ENABLED on the WLC), sends a DHCP discover to the dhcp server using the WLC subinterface IP assigned to that specific SSID.
Since that your dhcp is not responding (assuming WLC is properly configured and any FW in the middle of the path is not blocking that traffic), the WLC status for that connection is DHCP_REQUIRED as you saw.
The failure can be:
1.-misconfigured WLC interface for that specific SSID including DHCP ip value
2.-misconfigured DHCP scope for the WLC interface subnet
3.-firewall blocking traffic between wlc and dhcp.
Thanks for your comment.
In my network only one SSID does not work, others SSID is work and connect to the network.
The only difference is that a non-working SSID is authenticated via ISE, other SSID authenticated via daloradius. Via daloradius clients connect successfully, via ISE - not successful.
Error, it seems to me, not on the controller, but on the ISE.
Post removed, you are using 5760
This is weird. Can you use the same vlan and dhcp server for a wired vlan and try if you're getting an IP address.
When the client is stuck in that way, what's his status. Can you share printscreen of monitor client for that particular client?
Francesco
1. Can you use the same vlan and dhcp server for a wired vlan and try if you're getting an IP address.
No, this vlan is used only for wireless clients and I can't verify wired connect, sorry.
2. When the client is stuck in that way, what's his status. Can you share printscreen of monitor client for that particular client?
When client is authenticated his status is as follows:
1. He enters login and password and connects
2. He tries to authenticate and connect
3. then dropped or authenticated problem
In attachment screenshots of connecting to Wi-Fi network
Firstable, your ISE Logs shows that PEAP Authentication is working.
12306
11503
11002
From the WLC side, you are stuck on DHCP_Required status as shown in the logs provided. Check your DHCP configuration for the WLC interface.
What I'm asking is the client status on the WLC (you need to go on monitor, then client and the click on the client that's stuck and share this print screen).
Can you also share the authorization profile you're sending via ISE?
Others SSID are working but do they use all of them the same DHCP server?
Francesco
In the attachment client status on the WLC.
I'm use the default authorization profile (PermitAccess). Unfortunately, it is not possible to view it in detail. In the attachment configuration policy authentication and authorization.
In the attachment configuration work SSID and does not work SSID. The difference between them is only authentication via daloradius and ISE. SSID, that is authenticated via ISE does not work.
From your last reply I do NOT see the ISE Logs for that 'failed" connection but the client status for Policy Manager state = 8021.X required (not RUN). So, let's check everything from scratch including the SHARED KEY on WLC and ISE (network device list - WLC entry). Follow the steps indicated in the next link BUT select 802.1x ONLY as indicated in the screenshot below. You are missing the accounting part in your WLC configuration.
https://mrncciew.com/2013/12/16/configuring-radius-on-5760/
In the attachment configuration WLC 5760 and ISE. Thanks for the instruction. please explain which particular parameter affects the inoperability?
Thank you
