06-08-2011 11:54 AM - edited 03-10-2019 06:08 PM
I'm with problems to migrate the ACS 5.1 hardware to ACS 5.1 vmware. In my infraestructure I have a appliance with ACS 5.1 and I need to migrate to vmware to do HA. I installed vmware as the Cisco ACS recommendations. I made a backup of the ACS hardware and copied the local disk vmware ACS.
When I start the restore process after a few minutes an error occurs:
UMA/admin# dir
Directory of disk:/
33293306 Jun 08 2011 16:51:38 bkp-production-110608-1433.tar.gpg
5862 Nov 07 2009 01:06:32 favicon.ico.1
16384 Jun 06 2011 17:54:34 lost+found/
UMA/admin# acs restore bkp-production-110608-1433.tar.gpg repository Local
Restore requires a restart of application services. Continue? (yes/no) [yes] ? yes
Stopping ACS.
Stopping Management and View....................
Stopping Runtime...........................
Stopping Database....
Cleanup.....
Cannot find acsbackup_instance.log in the backup file
Starting acs
UMA/admin# sh application status acs
Application initializing...
Status is not yet available.
Please check again in a minute.
and the application does not start.
Can anyone help me?
06-09-2011 12:22 AM
do not know if this can help you, but what about to install vmware ACS 5.1 as a secondary instance to hardware version and then promote vmware ACS 5.1 to primary instance. There could be license problem of course.
Yours sincerely,
ZR
06-09-2011 07:08 AM
Hi ZR,
So I can to install vmware ACS 5.1 as secondary instance to hardware version. but I"ll have incompatibility problem ? or just only license problem.
Thank you for your time.
Best regards,
Carlos Fonseca.
06-10-2011 01:26 AM
Hi Carlos,
In order you can replicate your configuration from primary ACS 5.1 (hardware version) to secondary ACS 5.1 (vmware version), you need two different base line licenses (with different license ID). So, if you do not have two different base line licenses, you have got a problem. If you have CCO account you can try to download evaluation license from here https://tools.cisco.com/SWIFT/Licensing/PrivateRegistrationServlet?DemoKeys=Y just for the replication purpose (I am not quite sure whether evaluation license allow this). So, if you want to move configuration from vmware ACS, do the following:
Let us assume that your 1121 ACS has hostname HWACS and your vmware ACS has hostname VMACS. I also assume that HWACS is already installed.
1, Install ACS 5.1 on the vmware server (you have to use ESX 3.5 or 4.0 - ESXi is not supported by Cisco).
2, Install the same patch level as you have on the HWACS.
3, Install license file (with different license ID than on HWACS)
4, In web administration interface of VMACS (System Administration->Local Operations->Deployment Operations) insert information about your HWACS (IP address, admin username, password) and click register to primary.
5, Now your VMACS should have the same configuration as HWACS
6, Promote VMACS to primary server (System Administration->Local Operations->Deployment operations->Promote to primary)
7, Consider also whether you want VMACS to be the LogCollector (System Administration->Configuration->Log configuration->Log collector->select log collector server as VMACS and click Set log collector.
Please, if you can try to simulate this in lab.
By the way, restoring ACS backup created on 1121 ACS 5.2 version to vmware ACS 5.2 version worked for me without any problem.
Yours sincerely,
ZR
06-13-2011 12:44 PM
Hi ZR,
The problem solved.
The problem was in the backup via tftp, the file transfer was in error. After to make the backup via FTP, it worked the restore !
Thank for your time,
Best Regards,
Carlos Fonseca.
