problems about authentication proxy
zkjian517
Community Member
why does my cisco3640 router(ios version 12.1(3)) have no commands like "ip auth-proxy xxx"? thanks for any help!!!
mchin345
Level 11
Level 11
The "ip auth-proxy" command can be used in the global configuration mode and the interface configuration mode. In which mode is this not happening. This command was introduced with IOS version 12.0(5)T. For more information on this command use this URL.
http://www.cisco.com/univercd/cc/td/doc/product/software/ios123/123cgcr/secur_r/sec_i1g.htm#wp1069569
Hope this helps.
m.sir
Level 11
Level 11
You need IOS firewall feature set for auhtentication proxy
try feature navigator to find IOS for auhtentication proxy for your 3640
http://tools.cisco.com/ITDIT/CFN/jsp/index.jsp
