Problems with ACS View Eval
rd9689
I downloaded the ACS View install (CSCOacsvw4Eval.iso) and have tried loading it on a test VMWAre server (ver. 1.06 - Other Linux 2.6.x kernel VM). The install starts up, runs for about a minute and eventually aborts with the error;
IOError: (Errno 2) No such file or directory: '/tmp/smos.part'
My server is definately underpowered (Pentium 4, 1 GB of RAM), so that could be the issue. Any other ideas?
Thanks!
Bob
rd9689
The problem was not enough disk space. My initial VM had only 32 GB. I got a larger disk and a 50 GB VM and the install went well.
Tobi D
I see you have the problem is solved, i had the same
