Problems with callback and SecureID
csanoja
Community Member
Users can call to my 3640 and, after it authenticates them with AAA RADIUS, it makes a callback and it works fine. I need to authenticate the users with RADIUS and SecureID. The initial authentication works fine, but when the router calls back the koken has changed and the user is invalid...
I already have configured this in the asyn group:
ppp authentication pap callin
but the router still tries to authenticate the call out .
I see many people has this problem,,,, is any solution???
I use analog lines and this is the sh version:
IOS (tm) C2600 Software (C2600-IK2S-M), Version 12.1(1)T, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2000 by cisco Systems, Inc.
Compiled Fri 17-Mar-00 06:43 by ccai
Image text-base: 0x80008088, data-base: 0x80E4CC38
ROM: System Bootstrap, Version 11.3(2)XA4, RELEASE SOFTWARE (fc1)
RPCA_MT_202 uptime is 56 minutes
System returned to ROM by reload
System image file is "flash:c2600-ik2s-mz.121-1.T.r.bin"
cisco 2620 (MPC860) processor (revision 0x102) with 36864K/4096K bytes of memory.
Processor board ID JAD044201NR (4069313368)
M860 processor: part number 0, mask 49
Bridging software.
X.25 software, Version 3.0.0.
1 FastEthernet/IEEE 802.3 interface(s)
2 Serial(sync/async) network interface(s)
8 terminal line(s)
32K bytes of non-volatile configuration memory.
8192K bytes of processor board System flash (Read/Write)
Thanks....
gfullage
Sounds like you need to enable token-caching on the ACS server, this way it'll keep track of the old tokens for a defined period of time and automatically authenticate the callback. This is also used with ISDN/multilink calls for bringing up the second channel a short time after the first.
Under the Group settings on ACS, there's a section for Token Card's. Select Duration and say, 2 minutes and see how that goes. You may need to play with the time depending on your setup.
More information on token caching is available in the online docs.
csanoja
Community Member
Thanks, it worked fine.....!!
