Question on Universal Switch Config for ISE Guide
scamarda
On page 15, Step 8, the guide states the following:
SWITCH(config-if)#authentication event server dead action reinitialize vlan 10
I've always used 'authorize' and not initialize.  Have a customer that followed this guide and TAC is also telling him it should be authorize.
Can you clarify?
Thanks.
howon
It depends on the host mode that is used on the interface. See (Last item):
Top Ten mis-configured Cisco IOS Switch settings for ISE integration
howon
