Radius Problem Attriubte
Emerson Oliveira
Community Member
Help I have a Version: 1.1.4.218 ISE application and checking the logs I see the following message:
Radius,16/12/2013,12:56:41:704,WARN ,1271798672,NIL-CONTEXT,Class Attriubte not found,RADIUSHandler.cpp:413
Radius,16/12/2013,12:56:41:740,WARN ,1271798672,NIL-CONTEXT,Class Attriubte not found,RADIUSHandler.cpp:413
Radius,16/12/2013,12:56:43:221,WARN ,1271798672,NIL-CONTEXT,Class Attriubte not found,RADIUSHandler.cpp:413
Has anyone received or know why this post?
Amjad Abdullah
Do you experience any problem with the authentication besides this message?
Rating useful replies is more useful than saying "Thank you"
I have found this in my logs also and I have been to busy to find out the cause of this issue. Typically class attributes are not a mandatory attribute in most cases outside of VPN but then again it isnt really necessary in vpn unless the integration calls for it.
Tarik Admani
*Please rate helpful posts*
Thank you.
