06-07-2024 05:52 AM
Hello all,
I'm currently running a C9300 on 17.03.03 firmware. My security team has an AD RADIUS server that we have programmed into AAA which provides user groups with a privilege level. One of these privilege levels is for junior network admins to make basic changes like switch a vlan on a port, however I've come across an error that they're hitting when trying to write these changes to memory.
Switch#copy run start
Destination filename [startup-config]?
startup-config file open failed (Permission denied)
Switch#wr mem
startup-config file open failed (Permission denied)For transparency, here is the full permission 14 list:
privilege interface level 14 power inline
privilege interface level 14 shutdown
privilege interface level 14 ip address
privilege interface level 14 switchport
privilege interface level 14 no power inline
privilege interface level 14 no shutdown
privilege interface level 14 no ip address
privilege interface level 14 no switchport
privilege interface level 14 description
privilege interface level 14 no description
privilege configure level 14 interface
privilege exec level 14 write memory
privilege exec level 14 configure terminal
privilege exec level 15 reload
privilege exec level 14 test cable-diagnostics tdr interface
privilege exec level 14 show cable-diagnostics tdr interface
privilege exec level 14 show device-tracking database interface
privilege exec level 14 show ip interface
privilege exec level 14 show running-config
privilege exec level 14 showAny assistance would be greatly appreciated.
Solved! Go to Solution.
08-08-2024 05:31 AM
Happy to help!
