Remote Engine ID of ISE
sujanyakj
How to find the remote engine ID of ISE which will be used during snmp v3 configuration.
balaji.bandi
6 Replies 6
balaji.bandi
sotumu24/admin# show snmp-server engineID
Local SNMP EngineID: GKIILIFNGIC
check below information :
https://www.cisco.com/assets/sol/sb/Switches_Emulators_v2_2_015/help/nk_configuring_snmp05.html
https://www.cisco.com/c/en/us/support/docs/security/identity-services-engine/215521-configure-and-understand-snmp-traps-to-m.html
BB
tonyang
Reference the following command, may I ask if I need to input the Engine ID of remote SNMP server ? Thank you.
sotumu24/admin(config)# snmp-server host 10.127.197.81 version 3 SNMPUSER 0x474b49494c49464e474943 plain authpasswd privpasswd
depends on the requirement - read this :
BB
tonyang
I'd like to configure the SNMP (v3) in Cisco ISE. It's failed to input the command "snmp-server engineid remote/local".
XXX/admin(config)# snmp-server engineid ?
<WORD> EngineID String (Max Size - 24)
Hi @tonyang ,
 to configure SNMP v3 on ISE:
ise/admin# conf t
ise/admin(config)# snmp-server enable
ise/admin(config)# snmp-server engineid <the same UDI as show udi command> ise/admin(config)# snmp-server trap dskThresholdLimit <threshold> ise/admin(config)# snmp-server community <community> ro ise/admin(config)# snmp-server user <user> v3 plain <pass> <priv passwd>
Hope this helps !!!
follow the full thread from the beginning to get EngineID to add.
BB
