06-19-2019 08:33 PM
Hi All,
is it possible to set up Cisco ISE to support both guest self-registration and sponsor for the same SSID?
Cathy
Solved! Go to Solution.
06-20-2019 03:34 AM
06-19-2019 08:37 PM
For example
same guest landing page, guest can do self-registration, at the bottom of the land page, guest can click" if you have already been assigned a password at the reception sign in desk" to bypass the self-registration and use the password they have been allocated at the reception to connect to the Guest Wifi.
06-20-2019 03:34 AM
