SCRIPT CART WITH THREADS
amunoz
Frequent Visitor
Frequent Visitor
I'm working with CAR, i need to use a script, if the RADIUS_WORKER_THREAD_COUNT variable is 255, i need to configure some extra in the script to work with threads?
The script is very easy, is made to change a variable.
# more accdb.tcl
proc accdb {request response environ} {
$request put Framed-IP-Address [$request get RedBack-Assigned-IP-Address]
Not applicable
Increasing the number of worker threads also increases memory utilization. There is no upper limit to the number of RADIUS worker threads you can enable in your CAR server, but you should take care not to exceed your server's memory capacity.
http://www.cisco.com/en/US/docs/net_mgmt/access_registrar/4.2/user/guide/features.html
amunoz
Frequent Visitor
Frequent Visitor
But, i need to do someting diferent in the script?, or can i use the same script, if i am working with threads?.
