Solution for Monitoring Virtual ISE with Microsoft SCOM
MD SHAHNAWAZ
hi All,
Greetings!!!
i am looking for a solution to monitor our six virtual ISE nodes (Version 2.7) health like Memory/CPU/Interface and services etc. using Microsoft scom monitoring tool. currently our scom team is monitoring cisco physical device comes with CIMC but we are looking solution for Virtual ISE, any lead and suggestions which can help us to save our back i really appreciate.
5 Replies 5
balaji.bandi
Hello @balaji.bandi.
thanks for your response, but i am looking for configuration for virtual ISE health monitoring using Microsoft scom,
currently we have SNMP V3 integrated with SolarWinds where we are seeing incorrect data capturing by SolarWinds due to which i am looking for alternate way.
what incorrect data you seeing ? can you explain more ?
BB
Hello @balaji.bandi and @thomas,
i got to know from cisco that Cisco ISE can be monitor using scom only if it is SNS appliance because SNS appliance are UCS based, but for VM it wont be supported instead they suggested us to try with SNMP based monitoring which Balaji has mentioned above.
thomas
It is safe to say that we are not familiar with Microsoft SCOM.
You have not specified the protocols that SCOM uses/supports/expects.
See the ISE Compatibility Guides for the Supported Protocol Standards, RFCs, and IETF Drafts by ISE.
