SSH authentication from ASA5505 to ACS 5.3 Not Using PAP
rickyQ
Hello there, i am evaluating ACS 5.3 with an ASA5505, by using password management in the IPSec tunnel config i am able to authenticate the VPN clients using mschapv2, however, the SSH sessions are authenticated using PAP
I have looked for days and days for an answer without success, is this by design?
Cisco documents state that SSH can be authenticated via  TACACS with PAP,CHAP or MSCHAPv1, however, i have no idea how to get this done. It seems to be default to PAP
From Cisco Doc:
TACACS+ Server Support
The security appliance supports TACACS+ authentication with ASCII, PAP, CHAP, and MS-CHAPv1
Ps: I know the "test" feature on ASA uses PAP.
Thanks!
Tarik Admani
Ricardo,
I think the documentation may leave you hanging in this case, you can use tacacs to authentication PPP connections hence that is why the section in the AAA for management specifies that TACACS supports chap authentication, but in the chart below this is for PPP authentication.
www.cisco.com/en/US/docs/security/asa/asa82/configuration/guide/l2tp_ips.html#wp1090907
Table 62-1     AAA Server Support and PPP Authentication Types
AAA Server Type
Supported PPP Authentication Types
LOCAL
PAP, MSCHAPv1, MSCHAPv2
RADIUS
PAP, CHAP, MSCHAPv1, MSCHAPv2, EAP-Proxy
TACACS+
PAP, CHAP, MSCHAPv1
LDAP
PAP
NT
PAP
Kerberos
PAP
SDI
SDI
Hope this helps,
Tarik Admani
*Please rate helpful posts*
