Strange fake0 interfaces and arp problem.
Hello.
I have discovered another problem with CAS server.
CAS IP = 192.168.9.9/23
CAS GW = 192.168.8.1
CAS DNS = 192.168.8.2
I can ping my Gateway, google IP ( 74.125.229.201 ) and all others hosts that are not on the same subnet. I can ping from any other host to my CAS too. The issue here is that I can't ping from CAS to any host inside local subnet 192.168.8.0/23. I have found that the problem is related with ARP on CAS. Look at this:
[root@nacserver ~]# arp -a
? (192.168.8.2) at 00:01:02:03:04:05 [ether] on fake0
? (192.168.9.98) at 00:01:02:03:04:05 [ether] on fake0
? (192.168.9.95) at 00:01:02:03:04:05 [ether] on fake0
? (192.168.8.1) at 00:01:02:03:04:05 [ether] on fake0
this above output is showed very slowly line by line. Here the ifconfig output.
[root@nacserver ~]#
[root@nacserver ~]#
[root@nacserver ~]# ifconfig
eth0      Link encap:Ethernet  HWaddr 5C:F3:FC:25:D4:61
          inet addr:192.168.9.9  Bcast:192.168.9.255  Mask:255.255.254.0
          UP BROADCAST RUNNING MULTICAST  MTU:1500  Metric:1
          RX packets:98821 errors:0 dropped:0 overruns:0 frame:0
          TX packets:42539 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:1000
          RX bytes:13491186 (12.8 MiB)  TX bytes:5588195 (5.3 MiB)
          Interrupt:169
eth1      Link encap:Ethernet  HWaddr 5C:F3:FC:25:D4:62
          inet addr:192.168.200.9  Bcast:192.168.201.255  Mask:255.255.254.0
          RX packets:739 errors:0 dropped:0 overruns:0 frame:0
          TX packets:39857 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:47296 (46.1 KiB)  TX bytes:4152502 (3.9 MiB)
          Interrupt:225
fake0     Link encap:Ethernet  HWaddr 00:01:02:03:04:05
          inet addr:192.168.9.9  Bcast:255.255.255.255  Mask:0.0.0.0
          RX packets:0 errors:0 dropped:0 overruns:0 frame:0
          TX packets:41171 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:0 (0.0 b)  TX bytes:5098562 (4.8 MiB)
fake1     Link encap:Ethernet  HWaddr 00:01:02:03:04:05
          TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:0 (0.0 b)  TX bytes:0 (0.0 b)
fake2     Link encap:Ethernet  HWaddr 00:01:02:03:04:05
          inet addr:192.168.200.9  Bcast:255.255.255.255  Mask:0.0.0.0
fake4     Link encap:Ethernet  HWaddr 00:01:02:03:04:05
lo        Link encap:Local Loopback
          inet addr:127.0.0.1  Mask:255.0.0.0
          UP LOOPBACK RUNNING  MTU:16436  Metric:1
          RX packets:1488 errors:0 dropped:0 overruns:0 frame:0
          TX packets:1488 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:0
          RX bytes:922688 (901.0 KiB)  TX bytes:922688 (901.0 KiB)
As you can see there are many fake interfaces which take the same IP from trusted (Eth0) and untrusted (Eth1) interfaces. I have no idea why even they exist. Please give me some advice to fix it.
Greettings.
5 Replies 5
jw.sl9
By default, your CAS/NAS will send ALL packets for local subnets out the UNTRUSTED interface. where your clients should be.
If you want to override this you can configure static routes in the GUI.  If you are doing this, I'd  suggest /32 for only the specific devices you need access to.
For more see:
http://www.cisco.com/en/US/docs/security/nac/appliance/configuration_guide/49/cas/s_addSrvr.html#wp1084954
The fake# interfaces are created internally (Linix Core :-)  for traffic and VLAN "subinterfaces".  They are okay.
I hope you find this answer useful, if it was satisfactory  for you, please mark the question as Answered.
Please rate post you consider useful.
-James
I hope you find this information useful, if it was satisfactory for you, please mark the question as Answered. Please rate post you consider useful. -James
but I still dont understand why cant ping from CAS, due to this I cannot resolve any dns too because dns server is on its local subnet.
Are the devices you want to ping on the trusted or untrusted side of the CAS?
If the DNS server is on the same subnet as the CAS, (trusted side I hope) create a /32 route to it.  Select the interface but leave the gateway blank.
-James
All hosts are on trusted interface including WLC, Wireless clients,DNS Server, DHCP Server and GW.
I added the /32 route and now i can ping DNS (192.168.8.2) but i still can't another host on the same subnet. Should I add the whole subnet route too? Will it affect the future AD SSO implementation?
Thanks in advance.
When configuring CAS in a virtual gateway you should not place the CAS on the same broadcast domain with your trusted resources including the manager. The only workaround is to add /32 routes, this is also seen in environments with hsrp since customer like to ping their CAS from time to time, and the icmp messages are not sourced from the virtual interface but from the physical svi interface of the active router.
This is documented and therefore you are experiencing something known.
