Switch Logging issue with IBNS 2.0 concurrent Dot1x and MAB
mstraessle
Level 4
Level 4
Hi community
I have a stupid issue with IBNS 2.0 while doing Dot1x and MAB concurrently.
Because for MAB devices the authentication using dot1x will fail since there is no supplicant responding, I alway get the following log messages:
%DOT1X-5-FAIL: Authentication failed for client (0080.64bf.abcd) on Interface Gi1/0/44 AuditSessionID 0A08161D00000ABC060A1234
Since we will have several thousend ports configured using both methods, I will get to much logs on my LMS. For sure I know I can lower the level from debugging or informational to any lower than 5, but I will miss these messages which are Important:
Dec 21 2016 16:07:27.019 CET: %SYS-5-CONFIG_I: Configured from console by abc123 on vty0 (10.17.1.2)
Any suggestions?
hslai
This is not a question on ISE.
I found this on Cisco support forum which might help you.
Filter Syslog on Router | Network Management | Cisco Support Community
logging discriminator Config facility includes SYS mnemonics includes CONFIG_I
hslai
