Tacacs+ Accounting Logging Problem
ho-r
I recently installed new copy of ACS4.2 with latest patch on Win2003 server, the problem I am having is any Tacacs+ accounting or admin related events are not logged, I checked logging is enabled for both services. Is this a permission problem on the Win2k3?
Roger.
darpotter
Level 5
Level 5
Obviously you have the logging targets enabled in the system config/Logging config...
Are you talking CSV, syslog or what?
CSLog does have its own service log which you could check for error messages.
The problem was caused by not have a separate AAA client configured for the this device in Network Configuration specifying Tacacs as the authentication method. The version before 4.1 allowed Radius data to share with Tacacs+, I should have read the Doc before upgrade.
Roger.
