Tacacs doesn't work without AS-override
Hello guys,
I hope you are good.
I was configuring a circuit and I could notice that without the command neighbor x.x.x.x as-override tacacs didn't work in my topology, I couldn't understand very well why it happened.
Francesco Molino
As-override isn't directly related to tacacs but depending of your topology, you weren't receiving tacacs IP.
Maybe tacacs is located on another site and route want learned because of same as. I can't really tell without knowing your topology.
Can you share a sketch of your design including bgp as ?
Francesco
PS: Please don't forget to rate and select as validated answer if this answered your question
Yesterday I did some tests and I could see that it was exactly the problem, because my traffic was passing through the same AS in some point. Thank you for your time. Now I have this knowledge fixed.
Have a good one.
Glad you found out why there was an impact.
You're welcome
Francesco
