Use same ACS for multiple forests
remco.gussen
Level 4
Level 4
Is it posible to use one ACS appliance to authenticate users in different Windows forests ?
It may be only possible when a trust relationship exists between the forests ?
Gr.
Remco
Yes, that is correct. We need to enable trust.
~JG
Please mark this thread resolved , so other can benefit.
Jagdeep Gambhir
Level 11
Level 11
Remco,
Yes,trust is reqd. Other way is to set up proxy
Cross-Forest Authentication
http://www.microsoft.com/technet/prodtechnol/winxppro/deploy/ed80211.mspx#EE
VAG
In this set up we would need one more radius server and also need to set up proxy in it.
~JG
Do rate helpful posts
Thank you. I only have 2 ACS appliances (redundant). The only solution is a trust.. Isn't it ?
gr.
Remco
~JG
