Using Guest Account for Device Policy Sets
Arie --
Does anyone ever try below scenario before?
I'm using Cisco ISE 2.3 for Device Administration (TACACS). One thing I want to try is using Guest Account created from Sponsor Portal to be using in Device Policy Sets for Authentication and Authorization.
First, I created 2 Guest Type called: Monitor & Read Only
Second, I created an account from Sponsor Portal and assigned in Read_Only Guest Type:1a7182f9-99c3-4c25-b70a-3916a5003594.jpg
Third, I setup the Device Admin Policy Sets. Now, I focused on Authorization Policy since the Authentication Policy is work for me.
After I save the policy above, I tried to test AAA on a Cisco Switch. Unfortunately, it fails on Authorization and got default Deny Shell Profile. Below is the result:1a7182f9-99c3-4c25-b70a-3916a5003594.jpg
I still don't know why the Authorization policy rule doesn't work for IdentityGroup. Does anyone here ever try this scenario before?
Thank you in advanced
Arie
Arie --
I would like to tell that there is a bug:
CSCvh12508
It makes authorization rule can't read the guest database and that's why my authorization rule doesn't work with guest type identity group.
Please paste all details from your shell profile "ReadOnly_Profile_Cisco"
David
Arie --
CSCvh12508
