Using ISE to block TOR IP’s from connecting to VPN concentrators
tgallawa
Is it possible to have ISE block TOR IP's from connecting to an ASA RAVPN?
Marvin Rhoads
ISE is the wrong solution for that requirement. Ideally have an upstream NGFW/IPS with geoblocking. Or use MFA (like Duo) with geofencing requirements enforced on the MFA client.
Colby LeMaire
Best option would be to use the firewall itself to block certain IP's from connecting.  Ideally, you would have a "filtering" router at your Internet edge that blocks known bad IP's, RFC 1918 IP's, and your own internal subnet IP's (RFC 2827/BCP 38).  That prevents your firewall from having to process a lot of junk, which uses up resources.
If you cannot block on your edge router or firewall, then you could try to look for the "Framed-IP-Address" attribute in your authentication requests and use a Regex to match against your bad list.  But that is not ideal or efficient.
Marvin Rhoads
