VPN concentrator using SDI for authentication - and IP addressing
arashid
I have setup SDI authentication on the VPN concentrator and it works perfectly - but I want it such that when a user is authenticated from the SDI server it then goes back to the concentrator and gives the user a specific IP...not from a pool.
Thanks in advance.
engel
Level 2
Level 2
Someone correct me if I am wrong, but I think your requirement is not possible to achieve. Except may be you can enable the RADIUS option on the SDI and create an attribute for an IP address to be passed to the authenticated user. This should be easy to do with a RADIUS server . You may consider using a RADIUS server + SDI server.
