Wired mab authorization to LDAP problems
chanyunchang
Can someone figure out that I configure the LDAP server for ISE authentication of MAB, but the session doesn't hit on the authorization policy of LDAP group, I thought maybe is incorrect value in the * Group Map Attribute or * Group Object Class.. I'm not sure what can I do..
10.jpg.
Overview
Event     5200 Authentication succeeded
Username     00:0C:29:0A:6B:B5
Endpoint Id     00:0C:29:0A:6B:B5
Endpoint Profile     Windows7-Workstation
Authentication Policy    Default >> MAB
Authorization Policy    Default >> Basic_Authenticated_Access
Authorization Result    PermitAccess
Authentication Details
Source Timestamp      2018-11-13 14:01:36.191
Received Timestamp      2018-11-13 14:01:36.204
Policy Server      ise1
Calling Station Id      00-0C-29-0A-6B-B5
IPv4 Address      192.168.92.171
Authentication Identity Store      TESTLDAP
Identity Group      test-whitelist
Audit Session Id      C0A85C6400000005004ADC22
Authentication Method      mab
Authentication Protocol      Lookup
Service Type      Call Check
Network Device      CR-2960
Device Type      All Device Types#switch#SW2960
Location      All Locations#Yangmei#CR
NAS IPv4 Address      192.168.92.100
NAS Port Id      GigabitEthernet0/5
NAS Port Type      Ethernet
Authorization Profile      PermitAccess
Response Time      64 milliseconds
Other Attributes
ConfigVersionId     134
DestinationPort     1645
Protocol     Radius
NAS-Port     50005
Framed-MTU     1500
OriginalUserName     000c290a6bb5
NetworkDeviceProfileId     b0699505-3150-4215-a80e-6753d45bf56c
IsThirdPartyDeviceFlow     false
AcsSessionID     ise1/331133428/16
UseCase     Host Lookup
SelectedAuthenticationIdentityStores     TESTLDAP
AuthenticationStatus     AuthenticationPassed
IdentityPolicyMatchedRule     MAB
AuthorizationPolicyMatchedRule     Basic_Authenticated_Access
CPMSessionID     C0A85C6400000005004ADC22
EndPointMACAddress     00-0C-29-0A-6B-B5
ISEPolicySetName     Default
IdentitySelectionMatchedRule     MAB
DTLSSupport     Unknown
HostIdentityGroup     Endpoint Identity Groups:test-whitelist
Network Device Profile     Cisco
IPSEC     IPSEC#Is IPSEC Device#No
Name     Endpoint Identity Groups:test-whitelist
IdentityDn     cn=000C290A6BB5,ou=OA,ou=MACAddresses,ou=MAC,dc=test,dc=com
gidNumber     503
uid     000c290a6bb5
RADIUS Username     00:0C:29:0A:6B:B5
Device IP Address     192.168.92.100
Called-Station-ID     DC:7B:94:16:53:85
CiscoAVPair      audit-session-id=C0A85C6400000005004ADC22
Result
User-Name     00-0C-29-0A-6B-B5
Class     CACS:C0A85C6400000005004ADC22:ise1/331133428/16
cisco-av-pair     profile-name=Windows7-Workstation
LicenseTypes     Base license consumed
Steps
      11001     Received RADIUS Access-Request
      11017     RADIUS created a new session
      11027     Detected Host Lookup UseCase (Service-Type = Call Check (10))
      15049     Evaluating Policy Group
      15008     Evaluating Service Selection Policy
      15048     Queried PIP - Normalised Radius.RadiusFlowType
      15041     Evaluating Identity Policy
      15013     Selected Identity Source - TESTLDAP
      24031     Sending request to primary LDAP server - TESTLDAP
      24017     Looking up host in LDAP Server - TESTLDAP
      24029     Host's attributes are retrieved - TESTLDAP
      24005     Host search finished successfully - TESTLDAP
      22037     Authentication Passed
      24715     ISE has not confirmed locally previous successful machine authentication for user in Active Directory
      15036     Evaluating Authorization Policy
      15048     Queried PIP - TESTLDAP.ExternalGroups
      15048     Queried PIP - Radius.NAS-Port-Type
      15048     Queried PIP - EndPoints.LogicalProfile
      15048     Queried PIP - Network Access.AuthenticationStatus
      15016     Selected Authorization Profile - PermitAccess
      11002     Returned RADIUS Access-Accept
If this is only condition, ISE obviously did not match as it went through other conditions configured in other policies as well.
Would suggest you to check the authorization policy configured and also test the user groups at Administration > Identity Management > External Identity Sources > LDAP > TESTLDAP > Groups > Select Groups from Directory. See if it returns the OA group for that user. If it does, if the authorization policy has the correct condition and if it still does not work, please reach out to TAC.
5 Replies 5
Surendra
ISE is checking the following attributes :
I would suggest you check the policies configured as well to see if the request matches any of these attributes, may be a screenshot would help.
Hi Surendra
I configured the policy to match external group.
Absolutely agree @Surendra the ISE match in your case default rule : wich is basic authentication access = permit ip any any
He Guys
topic is quite old & solution is probably already found. I can confirm that matching works against entire DN (meaning ExternalGroups is not exactly CN=OA under OU=MacGroups under OU=MAC & so on up. Instead (with equal op) it must be like CN=OA,OU=MACGroups,OU=MAC,DC=test,DC=com.
