AP inventory AIREOS
ariask93
Hi guys!
I knew in this world of automation, I trying to get an inventory of all AP's that are register in a WLC 5520 - AIREOS
This is part of my code.
df = pd.DataFrame()
data = {}
# obtiene la lista de ips a conectarse
with open("ipdiscoc.txt", "r") as f:
    ips = f.read().splitlines()
# recorre la lista de ips
for ip in ips:
    try:
        # establece la conexión al dispositivo
        device = ConnectHandler(
            device_type='cisco_wlc_ssh',
            ip=ip,
            port=22,
            username= username,
            password= password
        # ejecuta el comando para obtener la configuracion
        hostname = device.find_prompt()
        cdp = device.send_command('grep include NAME:|DESCR:|PID:|VID:|SN: "show ap inventory all"', use_textfsm=True, read_timeout=300, delay_factor=2)
        data[hostname] = cdp
        # crea un archivo con el nombre del host y la fecha actual
        print(f"La configuracion del dispositivo con IP {ip} ha sido guardada")
    except Exception as e:
        print(f"Error al conectarse al dispositivo con IP {ip}: {e}")
    finally:
        # cierra la conexion
        device.disconnect()
print(data)
for entry in data.keys():
    datadf = pd.DataFrame(data[entry])
    datadf["hostname"] = entry
    df = pd.concat([df,datadf])
df.to_excel("apsummary02.xlsx", sheet_name=hostname, index=False)
The problems is: When the command "grep include NAME:|DESCR:|PID:|VID:|SN: "show ap inventory all" is execute, the prompt is waiting to press a key to continue, so, I don't know how to send that key,bottom to continue with the straction of data.
(Cisco Controller) >grep include NAME:|DESCR:|PID:|VID:|SN: "show ap inventory all"
Press any key to continue..
Leo Laohoo
Before entering the grep command, use the command "config paging disable".
Leo Laohoo
It's not that. I tried before and I didn't work.
I found this solution:
When you send the command "conf terminal' prompt changes to reflect configuration mode, and it starts to look like Switch(config)# while netmiko still waits for Switch#
So alternatively, if you want to send commands one by one, you can set the expected prompt or use "send_command_timing"
