Cisco IOS XR 7.0.1 - Telemetry Subscription not working
I created a subscription (as in screenshot) - hardware5
But state it shows as 'NA'
I checked I am not receiving any data in grpc receiver and simple tcp json receiver (I tried json encoding with tcp as I am not sure if my device is 32 or 64 bit)
More details about hardware: R-IOSXRV9000-LC-C, R-IOSXRV9000-RP-C(Active)  [obtained by running - show platform]
1. How to check if required process are running or not?
2. Source interface I have given whatever I found in 'show interface ip brief' which contained same ip as my router ip. Is it correct?
 I used yang-suite for gRPC receiver and simple java for tcp/json
2 Accepted Solutions
No sure if that is the problem.
"All 64-bit IOS XR platforms support gRPC and TCP protocols. All 32-bit IOS XR platforms support only TCP protocol."
@Flavio Miranda Identified it to be 32-bit system. gRPC transport is not supported by 32-bits. I gave try with json/tcp and self-describing-gpb/tcp using a simple Java socket listener, it is working.
8 Replies 8
@divyanshukumarpcm
 I believe it would be important to determine which platform you have.
Run
show platform
share the output please
Thanks for your reply, here is output
RP/0/RP0/CPU0:rotXR9000-4#show platform
Wed Jan 29 12:03:51.077 UTC
Node Type State Config state
0/0/CPU0 R-IOSXRV9000-LC-C IOS XR RUN NSHUT
0/RP0/CPU0 R-IOSXRV9000-RP-C(Active) IOS XR RUN NSHUT
thanks for this info, so grpc won't work. json encoding on tcp is also giving same details ( as in image)
any solution ? maybe some process is not running ? incorrect source interface?
for json/tcp, however, my java listener on the destination has detected connection but inputstream has no message. The subscription detail in router still gives 'NA' in status.
