Exanic-X25 retransmission issue
shailendrakumar
Respected Members,
I am using dual Exanic X-25 cards one for two interactive[TCP] connections on individual port and one for Multicast data only.
I have attached hardware ,firmaware report and pcap file of both the ports in zip file.
I am facing retransmission issue while sending data towards remote end using exanic0 Interface: enp23s0 and Interface: enp23s0d1.
Development process followed is as suggested by ExaNIC Library (libexanic) Usage - ExaNIC User Guide (exablaze.com).
Below is small sample of my code :
Code to write data to socket :
do
hdrlen = exasock_tcp_build_header(fd,pktbuf,sizeof(pktbuf),0,0);
}while (hdrlen == -1 && errno == EAGAIN);
if (hdrlen == -1)
std::cout<< "exasock_tcp_build_header: "<< strerror(errno)<<std::endl;
return EXIT_FAILURE;
exasock_tcp_set_length(pktbuf,hdrlen,TPK->_size);
exasock_tcp_calc_checksum(pktbuf,hdrlen,pktbuf+hdrlen,TPK->_size);
if(exanic_transmit_frame(exBase[fd].tx,pktbuf,hdrlen+TPK->_size)==0)
if(exasock_tcp_send_advance(fd,TPK->buffer,TPK->_size)==-1)
std::cout << " Failed to instruct about send advance "<< exanic_get_last_error()<<std::endl;
Can someone please guide if there is any setup or programmatical
error?
Thanks & Regards
Update :1
If this not the right place to post this question can someone please help me with the correct location ?
Thanks & Regards
rajeshchoudary
Hi @shailendrakumar ,
          I am also facing same issue. did u find any solution?
i am facing retransmit while sending tcp data tx.
