NETMIKO to cisco
Dhikra Marghli
Level 9
Level 9
Hello
I wantto use language python Netmiko  to add some commands to 400 router cisco !!
for me it the first time i use pyhon Netmiko
so
i have switch layer  2 2960 cisco have username admin and password admin123
enbale secret admin123
so i want to add command snmp  to 400 switch cisco
so i want to test two switch cisco
so what's the scrpit correct can i add  command SNMP to two switch ??
iwait a reply from expert Python
Dhikra Marghli
Level 9
Level 9
I try to write exmple
from netmiko import ConnectionHandler
cat2960 ={
"device_type":"cisco_ios",
"ip":"10.20.20.2",
"username":"cisco",
"password":"cisco",
"secret":"sotetel123",
net_connect = ConnectHandler(**cat2960)
net_connect.enable()
ouput = net_connect.send_command("show vlan")
print(output)
for vlan in range(10,51,10):
config_commands = ["vlan" +str(vlan),"name Netmiko_vlan"+str(vlan)]
ouput = net_connect.send_config_set_commands
print (ouput)
print(output)
Traceback (most recent call last):
File "C:/python/Python310/ssh.py", line 1, in <module>
ImportError: cannot import name 'ConnectionHandler' from 'netmiko' (C:\python\Python310\lib\site-packages\netmiko\__init__.py)
how i can resolve this error message !
Seb Rupik
Hi there,
Have your tried:
pip install netmiko
cheers,
Seb.
yes i put this comand in cmd
You had some typos and incorrect syntax, try the following:
from netmiko import ConnectHandler
cat2960 = {
    "ip":"10.20.20.2",
    "username ":"cisco",
    "password":"cisco",
    "secret":"sotetel123"}
output = net_connect.send_command("show vlan")
print(output)
  output = net_connect.send_config_set_commands
  print (output)
print(output)
cheers,
Seb.
