WLC Webhook returns jibberish
RichardAtkin
Level 3
Level 3
I've written a really simple webhook listener in PHP and I've subscribed to it in the WLC.  The WLC says it successfully publishes data to the webhook, but all I get is jibberish blank characters, special characters, etc.  I tested the same webhook listener with an online API tester and it works fine - receives the POST and dumps it to a text file.  When I do the same thing from the WLC however, it's unintelligable.
Here's my code... It works fine with CURL, etc... but WLC returns jibberish.
webhooklistener.php
<html>
<body>
<?php
$file = "wlcwebhook.txt";
$request = file_get_contents('php://input');
file_put_contents($file, $request);
</body>
</html>
It's like I need to decrypt / decode it somehow, but I can't see any mention of the WLC sending anything other than plain text - did I miss something?  Or is it bust and it really is just posting crap?  Any ideas?
I'm using a vWLC on v8.8.100.0
Rich
5 Replies 5
Leo Laohoo
Richard,
8.8.100.0 was just released to the public about 24 hours ago. On a Saturday.
Not everyone has loaded this to their controllers yet.
Slackers!
Rebooted WLC a couple more times - and it works.  I tried to debug via 'Debug DX ...' on WLC too but it's not documented in the 8.8 Command Reference so a little trial and error, and it didn't reveal anything useful anyway.
Works now... JSON lovliness.
Nope - it's broken again.  Very intermittent... seems it fails more than it succeeds :(
Eric Garnel
Would you mind sharing your Webhook config on the WLC side? I'm working on something similar to import into Grafana
