2611xm prompting to erase flash
Steven Williams
Level 4
Level 4
Evertime I try to copy something to flash my 2611xm will prompt me to erase the entire flash??
I can ignore that and the file exists in flash, but why does it always prompt?
R3#copy run flash:baseline.cfg
Destination filename [baseline.cfg]?
Erase flash: before copying? [confirm]n
Verifying checksum...  OK (0x7860)
1199 bytes copied in 8.350 secs (144 bytes/sec)
R3#o^Z
R3#
R3#
R3#show flash
System flash directory:
File  Length   Name/status
  1   34584712  c2600-adventerprisek9-mz.124-15.T14.bin
  2   1199     baseline.cfg
[34586040 bytes used, 15221316 available, 49807356 total]
49152K bytes of processor board System flash (Read/Write)
AFROJ AHMAD
Hi Steven,
"The IOS defaults to that for all files loaded to the flash.  It's a  pain, but it doesn't matter what type of file you load to the flash it  will always prompt for a flash erase"
Also check the below link :
https://supportforums.cisco.com/docs/DOC-2019
Thanks-
Afroz
[Do rate the useful post]
****Ratings Encourages Contributors ****
Thanks- Afroz [Do rate the useful post] ****Ratings Encourages Contributors ****
AFROJ AHMAD
Hi Steven,
Thanks-
Afroz
