28xx/12.4(25b) - Not able to append EEM CLI output to flash
shimol1984
I am trying to use EEM on a 2800 running 12.4(25b) Adv IP,  to capture some output, when a particular syslog message is seen. When the syslog is seen, EEM runs but bails out, since it cannot write to flash.
router#sh ver | i IOS
Cisco IOS Software, 2800 Software (C2800NM-ADVIPSERVICESK9-M), Version 12.4(25b), RELEASE SOFTWARE (fc1)
router#
My EEM policy:
event manager applet EEM-TEST
event syslog pattern "TRACKING-5-STATE: 1 rtr 999999 state Up->Down"
action 1.0 cli command "enable"
action 2.0 cli command "ping 4.2.2.2 source Loopback0 | append flash:EEM"
action 3.0 cli command "traceroute 4.2.2.2 source Loopback0 | append flash:EEM"
action 4.0 cli command "ping 4.2.2.2 | append flash:EEM"
action 5.0 cli command "traceroute 4.2.2.2 | append flash:EEM"
action 6.0 cli command "more flash:EEM.txt"
When the event occurs, I see the event in below command, which confirms EEM runs:
router#sh event manager history events detailed
Load for five secs: 7%/1%; one minute: 8%; five minutes: 9%
Time source is NTP, 14:54:44.748 PDST Mon Aug 29 2011
No.  Time of Event             Event Type          Name
1    Sun Aug28  22:07:08 2011  syslog              applet: EEM-TEST
msg {Aug 28 22:07:08.063: %TRACKING-5-STATE: 1 rtr 999999 state Up->Down}
2    Sun Aug28  22:09:38 2011  syslog              applet: EEM-TEST
msg {Aug 28 22:09:38.067: %TRACKING-5-STATE: 1 rtr 999999 state Down->Up}
3    Mon Aug29  04:06:39 2011  syslog              applet: EEM-TEST
msg {Aug 29 04:06:39.943: %TRACKING-5-STATE: 1 rtr 999999 state Up->Down}
4    Mon Aug29  09:36:41 2011  syslog              applet: EEM-TEST
msg {Aug 29 09:36:41.057: %TRACKING-5-STATE: 1 rtr 999999 state Down->Up}
5    Mon Aug29  12:24:11 2011  syslog              applet: EEM-TEST
msg {Aug 29 12:24:11.675: %TRACKING-5-STATE: 1 rtr 999999 state Up->Down}
6    Mon Aug29  14:26:37 2011  syslog              applet: EEM-TEST
msg {Aug 29 14:26:37.162: %TRACKING-5-STATE: 1 rtr 999999 state Down->Up}
7    Mon Aug29  14:30:12 2011  syslog              applet: EEM-TEST
msg {Aug 29 14:30:12.167: %TRACKING-5-STATE: 1 rtr 999999 state Up->Down}
8    Mon Aug29  14:37:12 2011  syslog              applet: EEM-TEST
msg {Aug 29 14:37:12.176: %TRACKING-5-STATE: 1 rtr 999999 state Up->Down}
9    Mon Aug29  14:44:12 2011  syslog              applet: EEM-TEST
msg {Aug 29 14:44:12.186: %TRACKING-5-STATE: 1 rtr 999999 state Up->Down}
10   Mon Aug29  14:48:42 2011  syslog              applet: EEM-TEST
msg {Aug 29 14:48:42.192: %TRACKING-5-STATE: 1 rtr 999999 state Up->Down}
router#
I did a "debug event manager action cli" and see below, which explains why flash does not have a 'EEM' file created:
Aug 29 14:48:42.196: %HA_EM-6-LOG: EEM-TEST : DEBUG(cli_lib) : : CTL : cli_open called.
Aug 29 14:48:42.196: %HA_EM-6-LOG: EEM-TEST : DEBUG(cli_lib) : : IN  :
Aug 29 14:48:42.208: %HA_EM-6-LOG: EEM-TEST : DEBUG(cli_lib) : : OUT :
Aug 29 14:48:42.208: %HA_EM-6-LOG: EEM-TEST : DEBUG(cli_lib) : : OUT : router>
Aug 29 14:48:42.208: %HA_EM-6-LOG: EEM-TEST : DEBUG(cli_lib) : : IN  : >enable
Aug 29 14:48:42.220: %HA_EM-6-LOG: EEM-TEST : DEBUG(cli_lib) : : OUT :
Aug 29 14:48:42.220: %HA_EM-6-LOG: EEM-TEST : DEBUG(cli_lib) : : OUT : router#
Aug 29 14:48:42.220: %HA_EM-6-LOG: EEM-TEST : DEBUG(cli_lib) : : IN  : #ping 4.2.2.2 source Loopback0 | append flash:EEM
Aug 29 14:48:42.232: %HA_EM-6-LOG: EEM-TEST : DEBUG(cli_lib) : : OUT :        ^
Aug 29 14:48:42.232: %HA_EM-6-LOG: EEM-TEST : DEBUG(cli_lib) : : OUT : % Invalid input detected at '^' marker.
Aug 29 14:48:42.232: %HA_EM-6-LOG: EEM-TEST : DEBUG(cli_lib) : : OUT : router#
Aug 29 14:48:42.232: %HA_EM-6-LOG: EEM-TEST : DEBUG(cli_lib) : : IN  : #traceroute 4.2.2.2 source Loopback0 | append flash:EEM
Aug 29 14:48:42.244: %HA_EM-6-LOG: EEM-TEST : DEBUG(cli_lib) : : OUT :        ^
Aug 29 14:48:42.244: %HA_EM-6-LOG: EEM-TEST : DEBUG(cli_lib) : : OUT : % Invalid input detected at '^' marker.
Aug 29 14:48:42.244: %HA_EM-6-LOG: EEM-TEST : DEBUG(cli_lib) : : OUT : router#
Aug 29 14:48:42.244: %HA_EM-6-LOG: EEM-TEST : DEBUG(cli_lib) : : IN  : #ping 4.2.2.2 | append flash:EEM
Aug 29 14:48:42.260: %HA_EM-6-LOG: EEM-TEST : DEBUG(cli_lib) : : OUT :                                                       ^
Aug 29 14:48:42.260: %HA_EM-6-LOG: EEM-TEST : DEBUG(cli_lib) : : OUT : % Invalid input detected at '^' marker.
Aug 29 14:48:42.260: %HA_EM-6-LOG: EEM-TEST : DEBUG(cli_lib) : : OUT : router#
Aug 29 14:48:42.260: %HA_EM-6-LOG: EEM-TEST : DEBUG(cli_lib) : : IN  : #traceroute 4.2.2.2 | append flash:EEM
Aug 29 14:48:42.272: %HA_EM-6-LOG: EEM-TEST : DEBUG(cli_lib) : : OUT :        ^
Aug 29 14:48:42.272: %HA_EM-6-LOG: EEM-TEST : DEBUG(cli_lib) : : OUT : % Invalid input detected at '^' marker.
Aug 29 14:48:42.272: %HA_EM-6-LOG: EEM-TEST : DEBUG(cli_lib) : : OUT : router#
Aug 29 14:48:42.272: %HA_EM-6-LOG: EEM-TEST : DEBUG(cli_lib) : : IN  : #more flash:EEM.txt
Aug 29 14:48:42.288: %HA_EM-6-LOG: EEM-TEST : DEBUG(cli_lib) : : OUT :
Aug 29 14:48:42.288: %HA_EM-6-LOG: EEM-TEST : DEBUG(cli_lib) : : OUT : %Error opening flash:EEM.txt (File not found)
Aug 29 14:48:42.288: %HA_EM-6-LOG: EEM-TEST : DEBUG(cli_lib) : : OUT : router#
Aug 29 14:48:42.288: %HA_EM-6-LOG: EEM-TEST : DEBUG(cli_lib) : : IN  : #exit
Aug 29 14:48:42.288: %HA_EM-6-LOG: EEM-TEST : DEBUG(cli_lib) : : CTL : cli_close called.
router#
Looks like parser does not like the flash:EEM part. I don't know why.
Some information on the file system and flash:
router#sh file systems
Load for five secs: 5%/1%; one minute: 7%; five minutes: 8%
Time source is NTP, 14:39:27.976 PDST Mon Aug 29 2011
File Systems:
     Size(b)     Free(b)      Type  Flags  Prefixes
           -           -    opaque     rw   archive:
           -           -    opaque     rw   system:
           -           -    opaque     rw   null:
           -           -   network     rw   tftp:
*   64016384    16502784      disk     rw   flash:#
      245752      143748     nvram     rw   nvram:
           -           -    opaque     wo   syslog:
           -           -    opaque     rw   xmodem:
           -           -    opaque     rw   ymodem:
           -           -   network     rw   rcp:
           -           -   network     rw   pram:
           -           -   network     rw   ftp:
           -           -   network     rw   http:
           -           -   network     rw   scp:
           -           -   network     rw   https:
           -           -    opaque     ro   cns:
router#show flash: all
Load for five secs: 6%/1%; one minute: 8%; five minutes: 9%
Time source is NTP, 14:54:13.851 PDST Mon Aug 29 2011
-#- --length-- -----date/time------ path
1     38187152 Jan 27 2010 17:17:40 -08:00 c2800nm-advipservicesk9-mz.124-25b.bin
2         1826 Aug 22 2006 12:55:44 -07:00 sdmconfig-28xx.cfg
3      4734464 Aug 22 2006 12:56:10 -07:00 sdm.tar
4       833024 Aug 22 2006 12:56:26 -07:00 es.tar
5      1052160 Aug 22 2006 12:56:44 -07:00 common.tar
6         1038 Aug 22 2006 12:57:00 -07:00 home.shtml
7       102400 Aug 22 2006 12:57:16 -07:00 home.tar
8       491213 Aug 22 2006 12:57:34 -07:00 128MB.sdf
9      1684577 Aug 22 2006 12:58:02 -07:00 securedesktop-ios-3.1.1.27-k9.pkg
10      398305 Aug 22 2006 12:58:22 -07:00 sslclient-win-1.1.0.154.pkg
11        4039 Sep 18 2006 14:03:12 -07:00 running-config
12         660 Jan 14 2009 16:46:34 -08:00 vlan.dat
16502784 bytes available (47513600 bytes used)
******** ATA Flash Card Geometry/Format Info ********
ATA CARD GEOMETRY
   Number of Heads:       8
   Number of Cylinders    490
   Sectors per Cylinder   32
   Sector Size            512
   Total Sectors          125440
ATA CARD FORMAT
   Number of FAT Sectors  62
   Sectors Per Cluster    8
   Number of Clusters     15629
   Number of Data Sectors 125301
   Base Root Sector       231
   Base FAT Sector        107
   Base Data Sector       263
ATA MONLIB INFO
   Image Monlib size = 61400
   Disk monlib size = 54784
   Name = piptom-atafslib-m
   Monlib Start sector = 2
   Monlib End sector = 100
   Monlib updated by = C2800NM-IPBASE-M12.3(8)T8
   Monlib version = 1
router#
Shimol
ngoldwat
Level 4
Level 4
Is there an EEM file present on flash?
I'm just guessing but it seems as though you would need to do something along the lines of:
Original
Proposed
action 1.9 cli command "delete /force flash:EEM"
action 2.0 cli command "ping 4.2.2.2 source Loopback0"
action 2.1 cli command "more $_cli_result | append flash:EEM"
Again, just a guess.
Thanks!
Addendum:
It is not possible to "more" a variable nor can you pipe ping.  So to achieve the desired result you will need to use Tcl.  When EEM 4.0 is released there may be some additional file manipulation abilities.
ngoldwat
Level 4
Level 4
Original
Proposed
Thanks!
Addendum:
Yup, that did it. Thanks for helping out !
