2960x Changing IPs and management VLAN
GONO
Hello
We need to change the IPs of our switches and their management VLANs. I wanted to know if there is any impact on the traffic running through the switch while doing so. We have a couple of stacks and I wanted to see what the best approach would be to minimize the impact.
G.
M02@rt37
Hello @GONO,
since it's the IP MGMT of your L2 Switch there's no impact. Change the SVI Management IP address and add the new vlan id on Trunk port(s) towards the L3 equipement.
Best regards
change the managment IP will not impact data pass through SW, BUT it effect some protocol use by SW for pass through data.
so only check if you use with any protocol source-IP <IP of SW management>
M02@rt37
Hello @GONO,
Best regards
GONO
Thank you both for your feedback!
You are so welcome
