3550 VLAN assignment for trunk ports
JP_Urkens
I'm writing an SNMP management application to control catalyst 3550/3750 switches and I am having problems figuring out how to change the VLAN assignments for trunk ports. The vmMembershipTable in Cisco-Vlan-Membership-MIB explicitly mentions that trunk ports aren't covered in this table although it doesn't mention where these are covered.
Not applicable
You could use CISCO-STACK-MIB .This MIB gives information on Trunks configured and the status of the Trunks.
You can start at 1.3.6.1.4.1.9.5.1.9 which is the VLAN group.
Keyan
Are you referring to the native vlan for the trunk?
Actually I've no idea whether there is a difference between the VLANs assigned to a trunk. I am looking for the SNMP equivalent of the CISCO IOS command:
"switchport trunk allowed vlan add VLANId"
Up to now I found the vlanPortTable in CISCO-STACK-MIB and vlanTrunkPortTable in CISCO-VTP-MIB. However both work with OCTET STRING(128) to specify VLAN settings for a trunk which is somewhat laborious.
