3750 IPSLA or SAA performance monitoring (RTTMON MIB)
         Am trying to setup performance monitoring(RTT and packet drops) using IPSLA with opennms monitoring tool. Data is not getting generated for the RTTMON OID when checked through NET-SNMP. Due to this graphs are not getting populated in Opennms. Am using below IOS on 3750 catalyst switch.Please can you suggest me what are MIB's files required for 3750 IOS for generating the RTT and packet drops graphs.
IOS : c3750-ipbasek9-mz.122-53.SE2.bin
Net-SNMP
snmpwalk -c public -v2c 172.168.11.2 .1.3.6.1.4.1.9.9.42.1.5.2.1.1.2
iso.3.6.1.4.1.9.9.42.1.5.2.1.1.2 = Gauge32: 0
govasrin
Hi Sricharan
I see "c3750-ipbasek9-mz.122-53.SE2.bin" supports "CISCO-RTTMON-MIB" .
http://tools.cisco.com/ITDIT/MIBS/MainServlet?IMAGE_NAME=c3750-ipbasek9-mz.122-53.SE2.bin
May i know the IP SLA operation that you are using in the device ?
please share "show ip sla configuration" and "show ip sla statics" output.
Also do snmpwalk for "1.3.6.1.4.1.9.9.42.1.5.2" and share output.
thank you.
Govardhan
Hi Govardhan,
           Thanks for response, Please find the attachment for the Logs. First I tried with IP sla configuration when there was no response from the RTTMON OID's then configured the IPSLA with rtr command. But still there was no luck.
