12-16-2014 05:14 AM
Hello Support,
We are trying to add the device 3750G in CPI 2.1.1 by using the Plug and Play feature. but the switch is not sending any DHCP discover to the DHCP Server. We are wondering if CPI 2.1.1 support the 3750G device. Could you please confirm that?
thanks!
12-16-2014 06:14 AM
Hi ,
It doesn't look like ,it is supported :(
http://www.cisco.com/c/en/us/td/docs/net_mgmt/prime/infrastructure/2-1/user/guide/pi_ug/setup_workflows.html#pgfId-1071182
Thanks-
Afroz
****Ratings Encourages Contributors ****
12-17-2014 06:08 AM
12-17-2014 06:30 AM
Great , I think I overlooked the document :(
Thanks-
Afroz
***Ratings Encourage Contributors ****
12-17-2014 06:45 AM
Hello Afroz,
Could you please confirm that the Plug and Play feature of CPI 2.1 is NOT support it on the 3750 G type device?
I have to be very sure with that...:-)
