01-03-2006 06:48 AM
I have 4500 SUP V module. I know it is used for 4510 and 4507, but can someone tell me if I can use it for 4506 chasis.
01-03-2006 06:52 AM
You can very well make use of the SUP module in 4506 do refer the supported SUPs in 4506 as mentioned in the below link..
http://cisco.com/en/US/products/hw/switches/ps4324/ps4333/index.html
regds
01-03-2006 06:57 AM
Actually, I have read some documents saying Sup V can be installed to a 4506 chasis. However, I tried it, and the swtich did not power up. So, I am not sure they are not compatible, or my SUP V engine has problem.
01-03-2006 07:15 AM
Is it a functional/working SUP module which you are trying out in this box ??
is it possible to try out in any other chasis ??
I feel if its mentioned in the datasheet then i think it shuld support but to make double sure and isolate the possiblities i would suggest to check out in another chasis if possible..
regds
01-03-2006 07:44 AM
Thanks for your reply. I have tried two different chassis already. But the blades includes the SUP V did not power up except the power supply.
Actaully, I just remember I have installed a Sup V to a 4506, and it works. So I think my SUP V is DOA. I just asked my sales guy for replacement.
