6500 logging
IB_LM20000
Community Member
Has anyone come across a probelm with bgp logging on 6509-e  with 12.2(17r)SX5 ?
My logs are full with log entries which i cannot get rid of no matter what:
BGP- ATF: EVENT XX.XX.XX.XX/32 RIB update DOWN
BGP- ATF: EVENT XX.X.XXX.X/20 RIB update MODIFY
BGP- ATF: EVENT X.XXX.XXX.X/20 RIB update MODIFY
BGP- ATF: EVENT X.XX.XXX.X/20 RIB update MODIFY
BGP- ATF: EVENT 0.0.0.0/0 RIB update UP
I see nothing in the configuration to log such, and # no debug all won't stop it either...!
Also, an identical unit with the same configuration does not show those.
Thanks!
