09-04-2009 01:00 AM
I have ciscoview 6.1.9 with lms 3.2. I upgraded 3.2 from 3.0 & 3.0.1.
I not see Cisco Catalyst 6509 Switch in Cisco View, i have new device package install:
31. Cat6000 9.1 Cat6000 Package
32. Cat6000IOS 30.1 Cat6000IOS Device Package
Message
Cannot find applicable device package for 1.1.1.1
This error could be due to one of the following:
- The device package for this device type is not installed.
- Device support for this device type is not available.
- You are trying to open a component inside a device.
To correct the problem, either install a device package for the device type, or open the parent device to manage the component.
Pls advise
Solved! Go to Solution.
09-07-2009 10:26 AM
Shutdown dmgtd, then copy all of the .zip files from /opt/CSCOpx/www/classpath/com/cisco/nm/xms/psu/pkgs/cvw to /opt/CSCOpx/MDC/tomcat/webapps/CVng/WEB-INF/classes/com/cisco/nm/cvw/devpkgs. Make sure the permissions are retained so that casuser:casusers is the owner:group. Then restart dmgtd, and you should be set.
09-04-2009 08:21 AM
What is the sysObjectID of this switch? Post the list of contents under NMSROOT/MDC/tomcat/webapps/CVng/WEB-INF/classes/com/cisco/nm/cvw/devpkgs and NMSROOT/www/classpath/com/cisco/nm/xms/psu/pkgs/cvw.
09-06-2009 11:53 PM
Hier the list of contents:
root:/opt/CSCOpx/MDC/tomcat/webapps/CVng/WEB-INF/classes/com/cisco/nm/cvw/devpkgs>> ls
AP1100.zip Cat2940.zip Cat6000.zip CVGenericPackage.zip Rtr10000.zip SOHO.zip
AP1200.zip Cat2948GL3.zip Cat8500.zip Entity.zip Rtr10700.zip SOHO70.zip
AP350.zip Cat2950.zip CatGL3.zip IAD2400.zip Rtr12000.zip StackMaker.zip
AS5300.zip Cat2955.zip CatQdm.zip IPv6.zip Rtr1400.zip SwitchAddlets.zip
AS5350.zip Cat2960.zip CBS30x0.zip MAR3200.zip Rtr1600.zip ubr7200.zip
AS5400.zip Cat2970.zip CE500.zip Metro1500.zip Rtr1700.zip ubr900.zip
AS5800.zip Cat3500XL.zip CE7300.zip MWR.zip Rtr1800.zip VG200.zip
AS5850.zip Cat3550.zip CGESM.zip Mwr1900.zip Rtr2500.zip VG224.zip
ASR1000.zip Cat3560.zip cigesm.zip NGMARShare.zip Rtr2600.zip VG248.zip
BR1300.zip Cat3750.zip Cisco2400ME.zip ONS_Share.zip Rtr2800.zip VPN3000.zip
BR1400.zip Cat4000.zip Cisco3400ME.zip ONS15501.zip Rtr3600.zip
Cat1900.zip Cat4200.zip CLIParser.zip ONS15530.zip Rtr3700.zip
Cat2820.zip Cat5000.zip CSS11000.zip ONS15540.zip Rtr3800.zip
Cat2900XL.zip Cat5500.zip CSS11500.zip Pix.zip SN5420.zip
root:/opt/CSCOpx/www/classpath/com/cisco/nm/xms/psu/pkgs/cvw>> ls
AP1100.zip Cat2940.zip Cat6000.zip CSS11500.zip ONS15540.zip Rtr3700.zip
AP1200.zip Cat2948GL3.zip Cat6000IOS.zip CVCrossLaunch.zip Pix.zip Rtr3800.zip
AP350.zip Cat2950.zip Cat8500.zip CVGenericPackage.zip PoE.zip Rtr7000.zip
AS5300.zip Cat2955.zip CatGL3.zip Entity.zip Routershare.zip Rtr800.zip
AS5350.zip Cat2960.zip CatQdm.zip IAD2400.zip Rtr10000.zip SN5420.zip
AS5400.zip Cat2970.zip CBS30x0.zip IPv6.zip Rtr10700.zip SOHO.zip
AS5800.zip Cat3500XL.zip CBS31x0.zip MAR3200.zip Rtr12000.zip SOHO70.zip
AS5850.zip Cat3550.zip CE500.zip Metro1500.zip Rtr1400.zip StackMaker.zip
ASR1000.zip Cat3560.zip CE7300.zip miniRMON.zip Rtr1600.zip SwitchAddlets.zip
BR1300.zip Cat3750.zip CGESM.zip MWR.zip Rtr1700.zip ubr7200.zip
BR1400.zip Cat4000.zip cigesm.zip Mwr1900.zip Rtr1800.zip ubr900.zip
Cat1900.zip Cat4000IOS.zip Cisco2400ME.zip NGMARShare.zip Rtr2500.zip VG200.zip
Cat2820.zip Cat4200.zip Cisco3400ME.zip ONS_Share.zip Rtr2600.zip VG224.zip
Cat2900XL.zip Cat5000.zip CLIParser.zip ONS15501.zip Rtr2800.zip VG248.zip
Cat2918.zip Cat5500.zip CSS11000.zip ONS15530.zip Rtr3600.zip VPN3000.zip
09-07-2009 10:26 AM
09-07-2009 10:19 PM
Thank you, it functions
