7200VXR Router IOS Upgrade Question
I am not sure if this is in the correct forum or not, but I have a question regarding an IOS upgrade for a 7204VXR router.
I have a (really old) 7204VXR router that currently has c7200-a3js-mz.121-6 as its IOS image. I would like to upgrade it to a version in which its features contain 'show ip flow top-talkers'
Below are the router details:
IOS (tm) 7200 Software (C7200-A3JS-M), Version 12.1(6), RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2000 by cisco Systems, Inc.
Compiled Wed 27-Dec-00 18:25 by kellythw
Image text-base: 0x60008950, data-base: 0x61BE2000
ROM: System Bootstrap, Version 12.0(19990210:195103) [12.0XE 105], DEVELOPMENT SOFTWARE
BOOTFLASH: 7200 Software (C7200-BOOT-M), Version 12.0(9)S, EARLY DEPLOYMENT RELEASE SOFTWARE (fc1)
cisco 7204VXR (NPE300) processor (revision D) with 57344K/40960K bytes of memory.
Processor board ID 18281318
R7000 CPU at 262Mhz, Implementation 39, Rev 1.0, 256KB L2, 2048KB L3 Cache
4 slot VXR midplane, Version 2.0
Last reset from power-on
Bridging software.
X.25 software, Version 3.0.0.
SuperLAT software (copyright 1990 by Meridian Technology Corp).
TN3270 Emulation software.
1 FastEthernet/IEEE 802.3 interface(s)
4 Token Ring/IEEE 802.5 interface(s)
1 IBM channel interface(s)
125K bytes of non-volatile configuration memory.
20480K bytes of Flash PCMCIA card at slot 0 (Sector size 128K).
4096K bytes of Flash internal SIMM (Sector size 256K).
Configuration register is 0x102
What IOS version for this particular router would have the 'top talkers' feature?
Thank you
try here:
http://tools.cisco.com/ITDIT/CFN/
you can search by platform or feature
res
Paul
Kind Regards
Paul
