10-06-2015 05:49 AM
Could somebody tell me the way to disable 802.1X for the specific port via snmp command?
i.e, I can do it from the cli "no authentication port-control auto". But I need this to be done in more 'scriptable' form.
as we can disable/enable port like this:
SET ON(1)/OFF(2) per interface ID
snmpset -v2c -c private switch.host.name 1.3.6.1.2.1.2.2.1.7.10102 i 2
I've tried to browse the CISCO-PAE-MIB and didn't find the solution...
Any links or idea?
Thank you.
PS Catalyst 2960S Series...
Solved! Go to Solution.
10-07-2015 01:07 PM
not sure if it will work but you could try to set dot1xAuthAuthControlledPortControl to the default value (3:forceAuthorized):
snmpset -v2c -c private switch.host.name 1.0.8802.1.1.1.1.2.1.1.6.<port-index> i 3
(Note that the Cisco Object Navigator showes an incorrect OID.)
Rolf
10-07-2015 01:07 PM
Rolf
10-08-2015 01:32 AM
Looks very promising:
ifName.10003 = Fa0/3
switch#show run int fa0/3 | i auth
authentication host-mode multi-auth
authentication timer restart 300
authentication timer inactivity server
snmpset -v2c -c XXX switch.host.name 1.0.8802.1.1.1.1.2.1.1.6.10003 i 3
snmpset -v2c -c XXX switch.host.name 1.0.8802.1.1.1.1.2.1.1.6.10003 i 2
Rolf
10-20-2015 01:04 AM
Yes, that's exactly what I need! Thank you for the help, Rolf!
Never thought it is possible to mess out with incorrect oids' digits!
