9300 Catalyst switch ssh access and management port
cyberops123
I am currently working on 9300 switches for DMZ network upgrade and I have couple questions regarding this switch .
 1-Does anyone know if the control plane and data plane are seperated completed or together on this switch ? cause I see there is a management interface in the back and we are planning to use that port giving  IP address connecting to internal Core switch for access .I just wanna make sure we dont create security issue here .
2-I configured ssh access on this switch and I am only able to ssh from management port and getting ssh error from network ports for some reason. they are all in vlan 1 and I basically created SVI for VLAN 1 with giving iP address but when I test with my laptop directly connecting , I get ssh error however I am able to ping management interface .
I also check line vty access list and there is nothing blocking on that .
Any idea what might be the issue ?
I would appreciate if I get help on my questions
Thanks again
balaji.bandi
Management port can be use for OOB Management purpose.
For your case you need to take some extra steps, Since this DMZ.
1. Make sure this connecting port is secure and only given access IP range can only access.
2. VLAN 1 is bad idea, suggest to use any other VLAN.
3. SSH error, what is the error you getting ? have you created RSA keys ?
post full configuration.
BB
