01-09-2014 12:45 AM
I have been coding massive amounts of TCL scripts for IOS and frankly, now that I'm comfortable with TCL as a language I want to make the next move. I have not been able to find a good starting point just yet to make the jump.
I am currently waiting for a copy of the Cisco TCL programmer guide (found a used one) to show up in the mail, but this will take nearly a month.
Can someone take the following script :
foreach a [ list 6 7 8 9 79 80 81 82 83 84 85 86 87 ] {
clear line $a
And help me convert this so that if I type :
host# clearlab
on the CLI, it will trigger the script and for each "[confirm]" message that shows up, it sends a carriage return.
So far, I have found that I need to register an EEM event (not so hard) and I'll need to import the Cisco libraries. I believe I'll need to also save this to flash using puts [ open...
Any help would be immensly appreciated!
01-09-2014 06:58 AM
What is the event you want to use to trigger the clear line?
01-10-2014 01:31 AM
Joseph,
Thanks for the response.
As mentioned above... I'd like to make use of the CLI event of a user typing clearlab
01-10-2014 07:23 AM
You could do an applet like:
event manager environment vty_lines 6 7 8 9 79 80 81 82 83 84 85 86 87
event manager applet clear-vtys
event cli pattern "^clearlab" enter
action 000 cli command "enable"
action 001 foreach a $vty_lines
action 002 cli command "clear line $a" pattern "confirm"
action 003 cli command "y"
action 004 end
01-10-2014 10:14 AM
Certainly! But it wouldn't help me to learn how to properly trigger TCL scripts from the command line
I only recommended that particular example randomly. I actually plan to use it as a template to hopefully do much grander things
Thanks a lot for this one though, it is also going into my library under "sometimes simple tasks are best done simple"
01-10-2014 10:16 AM
You can take that applet to http://www.marcuscom.com/convert_applet to get the EEM Tcl version. The results from that site can give you an EEM Tcl policy that you can register and trigger using the same clearlab command.
