03-27-2013 01:49 AM
Hi guys,
1.When I want to add a CPU alarm, prompted me:
Message
Failed to Create Alarm !
Cause
1)Could be invalid value for some of the entries
2)Could be due to lack of access to the host,invalid SNMP credentials or a busy device.
Action
1)Verify the values entered for all the entries.
2)Verify that the Alarm Variable resolves to one of the following ASN.1 primitive types
. INTEGER
. Integer32
. Counter32
. Counter64
. Gauge
. TimeTicks
3) Verify access, SNMP credentials or increasing timeout value through
Message
Cause
Action
. INTEGER
. Integer32
. Counter32
. Counter64
. Gauge
. TimeTicks
2.After I enable HTTPS ,login LMS finished entering username password I need to manually modify the port number. Link
I need change 1741 to 443, otherwise, can not access
3.Topology Services. It prompts me to download Java again and again
Every time I have installed have prompted this
But have not been able to properly display
Help me, please
Thanks a lot
03-27-2013 05:59 AM
Hi ,
For the First issue :: try to delete and re-add the device ,make sure you have the correct SNMP credentilas
Second Issue:
Delete the existing shortcut and create new one by following the below steps.
1. Right click on the desktop , choose New Shortcut.
2. Shortcut wizard appears, enter http://
3. Enter Cisco Works for name and click Finish.
4. Right click on the newly created icon ,choose properties , click on Change Icon and select Cisco works icon from the
location
Third Issue:
manually copied the following three required
jar files [(avalon-framework-4.1.5-sign-1-3.jar, jacorb-sign-1-3.jar, and
logkit-1.2-sign-1-3.jar) ] from the %NMSROOT%/htdocs/campus/res directory to the CLIENT MACHINE
C:\Program Files\Java\jre6\lib\endorsedd
Hope this will help you !!
Afroz
03-27-2013 08:24 PM
Hi ,dear Afroz
Thanks for your help
The Third Issue has been resolved,the other two did not.
For the first problem:
Can you tell me which is the correct Trap Community?
I use the SNMPV3 .
My configuration is as follows:
snmp-server community RORORO RO
snmp-server community RWRWRW RW
snmp-server group lms v3 priv
snmp-server user cisco lms v3 authen md5 cisco123 priv aes 128 cisco123
snmp-server host 10.10.10.10 inform ver 3 authen cisco
snmp-server host 10.10.10.10 traps ver 3 priv cisco
snmp-server engineID remote 10.10.10.10 upd-port 162 12a123dd123
snmp-server enable traps
Will the configuration error ?
Why engineID has been randomly? E.g. :80000009030058BFEAAEDD01 .It's not my want.
And in the figure above, I should fill which?
For the second problem:
I use the client machine .
I enter the URL directly,e.g. https://10.10.10.10 but the URL go to http://10.120.16.120:1741.
I guess this has nothing to do with the shortcut
Help me
10-15-2014 06:47 AM
I too had the problem with the jar files!
Thank you so much for your answer Afroz!
