A serious problem for LMS 4.1
CSCO11616177
Hi guys,
        1.When I want to add a CPU alarm, prompted me:
Message
Failed to Create Alarm !
Cause
1)Could be invalid value for some of the entries
2)Could be due to lack of access to the host,invalid SNMP credentials or a busy device.
Action
1)Verify the values entered for all the entries.
2)Verify that the Alarm Variable resolves to one of the following ASN.1 primitive types
. INTEGER
. Integer32
. Counter32
. Counter64
. Gauge
. TimeTicks
3) Verify access, SNMP credentials or increasing timeout value through
Message
Cause
Action
. INTEGER
. Integer32
. Counter32
. Counter64
. Gauge
. TimeTicks
        2.After I  enable HTTPS ,login LMS finished entering username password I need to manually modify the port number. Link 111.jpg
I need change 1741 to  443, otherwise, can not access
3.Topology Services. It prompts me to download Java again and again
Every time I have installed have prompted this
But have not been able to properly display
Help me, please
Thanks a lot
AFROJ AHMAD
Hi ,
For the First issue :: try to delete and re-add the device ,make sure you have the correct SNMP credentilas
Second Issue:
Delete the existing shortcut and create new one by following the below steps.
1.       Right click on the desktop , choose New Shortcut.
2.       Shortcut wizard appears, enter http://:1741 for location and click Next.
3.       Enter Cisco Works for name and click Finish.
4.       Right click on the newly created icon ,choose properties , click on Change Icon and select Cisco works icon from the
location \MDC\etc\.ico and click finish.
Third Issue:
manually copied the following three required
jar files [(avalon-framework-4.1.5-sign-1-3.jar, jacorb-sign-1-3.jar, and
logkit-1.2-sign-1-3.jar) ] from the %NMSROOT%/htdocs/campus/res directory to  the CLIENT MACHINE
C:\Program Files\Java\jre6\lib\endorsedd
Hope this will help you !!
Afroz
Thanks- Afroz [Do rate the useful post] ****Ratings Encourages Contributors ****
Hi ,dear Afroz
      Thanks for your help
      The Third Issue has been resolved,the other two did not.
      For the  first problem:
                  Can you tell me which is the correct Trap Community?
                 I use the SNMPV3 .
                 My configuration is as follows:
                       snmp-server community RORORO RO
                       snmp-server community RWRWRW RW
                       snmp-server group lms v3 priv
                       snmp-server user cisco lms v3 authen md5 cisco123 priv aes 128 cisco123
                       snmp-server host 10.10.10.10 inform ver 3 authen cisco
                       snmp-server host 10.10.10.10 traps ver 3 priv cisco
                       snmp-server engineID remote 10.10.10.10 upd-port 162 12a123dd123
                       snmp-server enable traps
                Will the configuration error ?
                Why engineID has been randomly? E.g. :80000009030058BFEAAEDD01 .It's not my want.
               And in the figure above, I should fill which?
         For the second problem:
               I use the client machine .
              I enter the URL directly,e.g. https://10.10.10.10  but the URL go to http://10.120.16.120:1741.
           I guess this has nothing to do with the shortcut
  Help me
I too had the problem with the jar files!
Thank you so much for your answer Afroz!
