a simple EEM script is needed
guan
Community Member
Hi Guys,
Does someone have a easy to use example tcl for "IOS-XR"  which does the following:
if syslog says "xxx" collect the following show command and save it on the local disk.
many thanks
Guan
Joe Clarke
Here's an example from IOS, but the exact same code will work on IOS-XR.  This script will react to a specific syslog pattern, run the "show proc cpu sorted 5min" command, then save the output to disk0:/output.txt.  I think this should be relatively straightforward to modify to suit your needs.
guan
Community Member
Hi Joseph,
Thanks a lot, i will try this out.
Kind Rgds
Guan
